keyboard charging fault, chip "most likely damaged", how to be sure?
The battery component of my pinephone keyboard is malfunctioning with symptoms described exactly in megi's FAQ, so I'm just quoting them here (emphasis mine):
Quote:Phone is not charging from the keyboard battery at all and keyboard power button does nothing
If
/sys/class/power_supply/ip5xxx-battery/uevent
does not become available, even when connecting the USB power supply to the keyboard, and is empty, that means that the charger chip is not responding, even when powered up. That means the chip is most likely damaged.
(source: https://xnux.eu/pinephone-keyboard/faq.html)
"most likely damaged", it says. Is there a known alternative possibility that I could test for, and possible ways to fix the unit?
I have had the keyboard for only a month and have barely used it. I was very aware that I should never charge it through the phone's USB-C socket and I am pretty sure I didn't. I did leave it connected to a charger via the keyboard's socket for a week once and maybe that's when the fault happened, although that still seems surprising to me.
I got it working again. The trick was to press the keyboard's power button *while* it was connected to a power supply.
  Rii mini 4 keyboard and touchpad work over Bluetooth Peter Gamma 2 3,384 06-04-2026, 12:16 PM
Last Post: elinkser
  Pinephone (Pro) Keyboard Case for sale manubert 8 17,000 05-15-2026, 11:36 AM
Last Post: oliveira11670
  NEW pinephone keyboard case and LoRa backplate for sale ragele 0 1,883 01-12-2026, 06:09 PM
Last Post: ragele
  keyboard case charging but not typing new2pinephone 19 23,229 02-14-2025, 04:09 PM
Last Post: zltpxqhp69o2
  Searching for a PinePhone Keyboard Case RubiksCube 1 4,432 10-07-2024, 11:08 PM
  So which keyboard you suggest for the Pinephone? Peter Gamma 21 19,178 07-19-2024, 08:05 AM
Last Post: Peter Gamma
  Bring the Pinephone keyboard back, it is worth it! Peter Gamma 1 4,379 07-04-2024, 07:32 AM
Heart The Pinephone keyboard offers alternative layouts Peter Gamma 0 2,491 07-04-2024, 05:40 AM
  Keyboard & 2.4G usb dongle for the Pinephone? Peter Gamma 2 3,991 06-29-2024, 09:36 PM
  Bluetooth keyboard with trackpad Zebulon Walton 11 20,888 06-29-2024, 04:09 AM
