How to check which mobian build I am running
is there a way to check, which version of mobian I am exactly running?
I mean if I take the list of weekly builds as reference, is it possible to see, which weekly build I am running?
The information delivered by e.g.
lsb_release -a
and similar commands don't provide that information.
Thanks!
  bookworm vs trixie discussion for mobian in pinephone regular. zetabeta 17 2,095 Yesterday, 05:47 AM
Last Post: diederik
  Mobian repository status henrythemouse 16 8,803 04-10-2024, 10:02 AM
Last Post: diederik
  cant verify mobian image at website gnugpg penguins_rule 0 136 03-18-2024, 08:54 PM
Last Post: penguins_rule
  mobian installed to eMMC - how to install tow-boot grump_fiddle_reinstall 6 2,013 11-22-2023, 11:46 AM
Last Post: aLoop100o
  How to check if tow-boot is installed? jojuma 3 943 09-29-2023, 11:29 PM
  What actions needed to keep on mobian testing user641 3 1,836 09-05-2023, 06:44 AM
  Mobian boot failed with zstd message after upgrade. Mahgue 0 637 09-01-2023, 11:29 AM
Last Post: Mahgue
  how to update mobian over tor vusra 13 6,936 07-09-2023, 08:57 PM
Last Post: vusra
  opensnitch outbound firewall now works on mobian vusra 2 1,908 07-09-2023, 01:37 AM
Last Post: vusra
  Using Nativefier on PP64 with Mobian paulcarton 0 635 07-05-2023, 03:57 AM
Last Post: paulcarton
