02-22-2023, 04:42 AM
That's my guess too, but it could also be an u-boot problem. If another boot loader would have the same issue, then it becomes even more likely to be a HW problem.
Need a working image for Quartz64B
02-23-2023, 02:03 AM
(02-22-2023, 04:42 AM)diederik Wrote: That's my guess too, but it could also be an u-boot problem. If another boot loader would have the same issue, then it becomes even more likely to be a HW problem. The reason is not u-boot. Before it, a binary blob starts controlling the primary memory configuration, u-boot and EDK2 use almost the same primary blob. There is no output since the start of the primary loader , which means the hardware is not working.
02-23-2023, 12:32 PM
(01-24-2023, 11:51 PM)balbes150 Wrote:(01-24-2023, 11:16 AM)diederik Wrote: I still need to look further into it, but I had the same issue with a Model-B, no output on both UART adapters (both woodpecker), while both work fine with Model-A. I think I've found the reason :-) I have a Model B v1.4 and @CounterPillow appears to have a v1.3 and his serial is working. Do you happen to have a v1.4 too?
02-24-2023, 12:11 AM
Ver 1.4 2022.06.06
Quartz64B eMMC boot failure | bsmorgan | 2 | 531 |
11-15-2023, 12:00 AM Last Post: balbes150 |
can't get quartz64-A working | jyoung | 14 | 4,506 |
04-29-2023, 04:41 PM Last Post: diederik |
Trying to get Quartz model A working | fasani | 2 | 2,232 |
09-17-2022, 06:43 AM Last Post: balbes150 |
