RK3566 Memory map
I can nowhere find any info regarding the location of the RK3566's memory mapped registers. The Rockchip data sheet contains much about the SoC's electrical specification, but, so far as I can see, nothing about programming the peripherals, or even the address at which main memory is to be found.
Any ideas?
For this you need to consult the TRM, not the datasheet. The RK3566 TRM can readily be found online, though I won't link to it here since I don't know how permitted any of those uploads are. Anyway, here's the address map from it:
https://overviewer.org/~pillow/up/d712e8...essmap.pdf
For the individual registers at each of those addresses, please also consult the TRM. It's a very large document.
Occasional Linux Kernel Contributor, Avid Wiki Updater, Ask Me About Quartz64
Open Hardware Quartz64 Model A TOSLink Adapter
Pi-bus GPIO Extender For ROCKPro64 And Quartz64 Model A
Plebian GNU/Linux
(07-25-2022, 01:55 AM)CounterPillow Wrote: For this you need to consult the TRM, not the datasheet. The RK3566 TRM can readily be found online, though I won't link to it here since I don't know how permitted any of those uploads are. Anyway, here's the address map from it:
Thanks. I was searching high and low for the TRM last night (London time), and couldn’t find it. This morning it took only a few attempts. It may be a large document, but ARM can easily beat it!
  RK3566 debug component clarification. Randomuser 0 1,085 08-13-2022, 06:54 PM
Last Post: Randomuser
  Does RK3566 support s2ram deep sleep? jag 0 1,416 09-27-2021, 12:16 PM
Last Post: jag
