PP Keyboard question
Hi All,
The battery on my PP keyboard is recognized by Mobian as a power source in Settings --> Power on my PP (not pro edition); however, there five (5) power sources are listed, which are: unlabeled (Discharging), Main (0%), Extra (0%), Extra (0%), Extra (70%).
The button on the right side of the keyboard does not activate/deactivate charging status. Does not work when I do a double press or a long press.
Note: I can use the keyboard for typing.
I have never used the usb-c port on the PP to charge the PP while it was in the PP keyboard, so this isn't the cause. I wonder if a possible cause is a software update (I use mobian).
The PP keyboard battery did charge the PP battery when I first received it, but stopped recently, which is when I noticed it not working. I don't know when this issue first began because I only plug in the keyboard for testing progress of optimizing the operating system power consumption/compatibility with the PP keyboard. When the PP keyboard battery was working with PP, the PP keyboard battery increased the duration of use of the PP by about 50%, hoped it would be more.
Wondering if others have experienced similar issue.
Thanks in advance for any helpful information.
Stay well.
i noticed that different os's show battery indicator differently and also charging. my guess is, it's a bug in a software.
this console program gives some info.
$ upower -d
at least i noticed that if screen is on, then keyboard barely charges the pinephone.
Thanks zetabeta! That's helpful.
I have similar symptoms under mobian right now. When the PP is connected to the keyboard Main never shows more than 24% no matter how long it charges and even if the PP is turned off when charging. If I charge the PP when removed from the keyboard case it charges to 100% but only shows max 24% when it is put back in the keyboard case.
The case battery gives a reading between 94 and 97% but does not appear to charge the phone battery.
So, have the keyboard drivers been borked again, creating charging issues or are 1st batch keyboards starting to slowly die?
(07-09-2022, 09:04 AM)zetabeta Wrote: i noticed that different os's show battery indicator differently and also charging. my guess is, it's a bug in a software.
$ upower -d
Thanks. I will try running that later with my PP in the keyboard case.
In my case replacing the circuit board in the keyboard fixed the charging problems.
However it never shows more than 66% with the Main and Extra batteries charged to 100% each. I assume the other 33% is assigned to the phantom battery which is not present. Also it appears that the "Extra" battery is the phone battery while the "Main" battery is the one in the keyboard.
  keyboard case charging but not typing new2pinephone 19 14,188 02-14-2025, 04:09 PM
Last Post: zltpxqhp69o2
  Searching for a PinePhone Keyboard Case RubiksCube 1 2,097 10-07-2024, 11:08 PM
  So which keyboard you suggest for the Pinephone? Peter Gamma 21 9,898 07-19-2024, 08:05 AM
Last Post: Peter Gamma
  Rii mini 4 keyboard and touchpad work over Bluetooth Peter Gamma 0 1,034 07-19-2024, 08:02 AM
  Bring the Pinephone keyboard back, it is worth it! Peter Gamma 1 2,057 07-04-2024, 07:32 AM
Heart The Pinephone keyboard offers alternative layouts Peter Gamma 0 813 07-04-2024, 05:40 AM
  Keyboard & 2.4G usb dongle for the Pinephone? Peter Gamma 2 1,782 06-29-2024, 09:36 PM
  Bluetooth keyboard with trackpad Zebulon Walton 11 14,085 06-29-2024, 04:09 AM
  Was someone able to use the Pinephone keyboard & an usb mouse at the same? Peter Gamma 4 6,555 06-26-2024, 07:11 AM
Last Post: dachalife
Exclamation USB mouse isn't working when a PP keyboard is attached? mikeb 6 4,605 06-25-2024, 12:10 AM
