RTC battery holder options
Hi , all
I didn't originally purchase an RTC battery holder with my Rockpro64 , honestly not knowing the benefit of having one. Now I would like to get one , however to purchase the one fro the pine store incurs a courier charge of £30 in the UK.
I thought I would be able to find loads of alternative options for such a simple device on ebay or amazon ( although of course I would rather get one from the pine store ) , but it seems a replaceable RTC battery holder is a rare thing.
does anyone know of anywhere I can get an alternative, or possibly know the name of the connector so I can "DIY" a standard AAA holder and add the connector ?
thanks in advance
Open: https://www.amazon.co.uk/
Search: '2xAAA Battery Cage with JST Connector'
You will find similar items to Pine64's
=> '2xAAA Battery Cage with JST Connector (for microbit)'.
https://pine64.com/product/rtc-backup-ba...r-2-x-aaa/
Please make your own purchasing decision after comparing with the above.
(06-19-2022, 06:41 AM)t4_4t Wrote: Open: https://www.amazon.co.uk/
Wow I can't believe it's that simple , I would have never found this if I had searched all day .
Thank you so much , I'm sure the pine store version is of a better quality but until I buy something larger from pine64 to justify the courier charge , I need to purchase this sooner rather than later.
Smile
  ROCKPro64 has Lithium Battery Port yes or no? anfast 3 5,560 06-25-2020, 02:09 PM
Last Post: anfast
  rtc battery check rahulsharma 0 1,586 01-15-2019, 09:05 AM
Last Post: rahulsharma
  RockPro64 Features/options working/not working lavermil 9 10,910 10-23-2018, 02:48 AM
Last Post: lavermil
