Images too large?
Exclamation
Hello!
I am trying to burn some rooted DD images of android from http://wiki.pine64.org/index.php/Pine_A6...e_20160505
I bought two 64gb sd cards from amazon from this link: https://www.amazon.com/gp/product/B00IVP...UTF8&psc=1
When I try to use Win32DiskImager to burn the 64gb images to the SD cards I get this error: http://imgur.com/fvVRSCG
Any idea on why the heck this is happening?
(07-07-2016, 06:44 PM)kikootwo Wrote: Hello!
Different brands of microSD of the same size report different actual storage capacities - thus what is '64GB' for a Samsung may not be the same as for a SanDisk, or a PNY or whatever. More all-encompassing dd images are in works, last I heard. Until then, your best option is to choose an image one size down - so for you that would mean choosing the 32GB image. Not ideal, I know, but at least then you can get up and running.
The alternative is to try and use the PhoenixCard software and a PhoenixCard image and burn things that way. This method has its own issues, but should be ok provided you don't try and burn a dd image with PhoenixCard. It won't work and you will get a 'script not found' error.
I had the similar issue with a 64GB card I had bought for my Pine and then I swapped it with the 32GB in my phone and no issues with that dd image.
You could do this on a Linux system, if the image is slightly to big.
cd /tmp
wget http://files.pine64.org/os/android/andro...4-64GB.zip  #Download the ZIP to the Linux system
unzip android-ver5.1.1-20160505-pine64-64GB.zip   # Unzip it to android-ver5.1.1-20160505-pine64-64GB.img
fdisk -l android-ver5.1.1-20160505-pine64-64GB.img  # Get the IMG partition info
omitting empty partition (14)
Disk android-ver5.1.1-20160505-pine64-64GB.img: 63.3 GB, 63282610176 bytes, 123598848 sectors
Units = sectors of 1 * 512 = 512 bytes
Disk label type: dos
Disk identifier: 0x00000000
                                                          Device Boot      Start         End      Blocks   Id  System
android-ver5.1.1-20160505-pine64-64GB.img1         5251072   123596798    59172863+   b  W95 FAT32
android-ver5.1.1-20160505-pine64-64GB.img2   *       73728      139263       32768    6  FAT16
android-ver5.1.1-20160505-pine64-64GB.img3               1     5251072     2625536   85  Linux extended
android-ver5.1.1-20160505-pine64-64GB.img5          139264      172031       16384   83  Linux
android-ver5.1.1-20160505-pine64-64GB.img6          172032      204799       16384   83  Linux
android-ver5.1.1-20160505-pine64-64GB.img7          204800     3350527     1572864   83  Linux
android-ver5.1.1-20160505-pine64-64GB.img8         3350528     3383295       16384   83  Linux
android-ver5.1.1-20160505-pine64-64GB.img9         3383296     3448831       32768   83  Linux
android-ver5.1.1-20160505-pine64-64GB.img10        3448832     5021695      786432   83  Linux
android-ver5.1.1-20160505-pine64-64GB.img11        5021696     5054463       16384   83  Linux
android-ver5.1.1-20160505-pine64-64GB.img12        5054464     5087231       16384   83  Linux
android-ver5.1.1-20160505-pine64-64GB.img13        5087232     5251071       81920   83  Linux
Partition table entries are not in disk order
Got the 73728 from the START col of .img2, would use 139264 for .img5, yada, yada, yada
echo "73728 * 512" | bc  # Calculate the offset
37748736
mkdir /mnt/from_part
mkdir /mnt/to_part
Use FDISK & MKFS to duplicate your Slightly small SD card to match the fdisk from the IMG. Here partition 1 should end up a bit smaller, normally this smaller partition would be the last, but that's not how this one came out.
# Mount your SD card onto /mnt/to_part, I'll let you figure this out
mount -o loop,owner,offset=37748736 /tmp/android-ver5.1.1-20160505-pine64-64GB.img /mnt/from_part/ # Mount the IMG partition #2
ls -l /mnt/from_part/  # Ouh see the Magic Big Grin , see what is on IMG partition #2
total 1358
drwxr-xr-x. 2 root root   2048 Dec 31  1979 bat
-rwxr-xr-x. 1 root root      0 Dec 31  2009 data.notfirstrun
-rwxr-xr-x. 1 root root 344813 Dec 31  1979 font24.sft
-rwxr-xr-x. 1 root root 357443 Dec 31  1979 font32.sft
-rwxr-xr-x. 1 root root    512 Dec 31  1979 magic.bin
cd /mnt/from_part/
tar -cf - . | ( cd /mnt/to_part; tar -xpvf - )./  # copy the files from the IMG partition to the SD
./font24.sft
./bat/
./bat/bat9.bmp
./bat/bat7.bmp
./bat/bat2.bmp
./bat/bat5.bmp
./bat/bootlogo.bmp
./bat/bat0.bmp
./bat/bat8.bmp
./bat/low_pwr.bmp
./bat/battery.bmp
./bat/bat1.bmp
./bat/bat3.bmp
./bat/bempty.bmp
./bat/bat6.bmp
./bat/battery_charge.bmp
./bat/bat10.bmp
./bat/bat4.bmp
./bootlogo.bmp
./font32.sft
./magic.bin
./data.notfirstrun
tar: .: implausibly old time stamp 1969-12-31 16:00:00
ls -l /mnt/to_part/  # look they match
total 1368
drwxr-xr-x. 2 root root   4096 Dec 31  1979 bat
umount /mnt/from_part
umount /mnt/to_part
# Rinse, Repeat for each partition in the IMG
Good luck,
BigBear
I also ran into this issue when attempting to write the 16GB image to an 16 GB microsd card using Win32DiskImager. I was using a Samsung 16GB PRO MicroSD Card ( Model: MB-MG16EA/AM ) that I purchased on Newegg.
System Specs:
  • Windows 10 Pro (64-bit edition)
  • Win32DiskImager version 0.9.5
  • 16 GB DDR3 1600 memory
  • ASRock Fatal1ty 970 Performance
  • Rosewill RDCR-11004 ( Rosewill Product page, for those in the United States, you can find this on Newegg.)
This images done for DD cannot be used with the Win32 Diskimager.
Select the "Phoenix Card image:" from further down on the list of images. Then Win32 Imager seems to work.
(07-17-2016, 11:24 PM)jimwrey Wrote: This images done for DD cannot be used with the Win32 Diskimager.
This is incorrect information. PhoenixCard images cannot be burned in Win32DiskImager, DD images cannot be burned using PhoenixCard.
Only images labelled as being for PhoenixCard can be burned using the PhoenixCard software.
Images labelled as being DD can be burned through a variety of applications, including Win32DiskImager and via a command line terminal.
Thanks, it appeared to burn okay ... but did not boot.
When trying to burn it with the PhoenixCard is says "script missing" ...
So, I won't chime in again ...
By all means chime in again. Everyone has an opinion and a right to share it. Even if wrong, as in this case, it helps to create a discussion and someone else reading this can say 'hey, that's what I thought too, glad these guys talked about it first and found out some stuff.'
Regarding this particular topic, it's one that I'm on the lookout for - trying to prevent confusion arising over different images and different burning options.
Thanks I appreciate the help.  There was another post (I think) from another poor lost soul that stated that you could only burn an Image with the DD from the command line ...
I will go back and try the DD file with Win32DiskImager ... as a former tech writer of manuals  picking through the how to posts and pages has been painful as they all seem to make assumptions that the read knows what they are doing.  I am proof that that is often NOT the case.  :>)
  Burning images on Mac (OSX) the easy way Luke 12 29,505 08-14-2016, 11:09 AM
Last Post: alexandros
  why are there different images based on sd card size? checktravis 2 6,200 07-28-2016, 08:41 AM
Last Post: xalius
