Gembird USB Typ-C to HDMI has no HDMI output when connected to PinePhone PostmarkedOS
https://www.galaxus.ch/de/s1/product/gem...lsrc=aw.ds
The Gembrid USB to HDM adapter can also be found on Aliexpress (with a different name)
Martijn Braam wrote here in the forum about another usb-c apapter with VGA output:
«In theory any dock that uses usb-c displayport alt-mode for the video ports should work (which most are). The usb3.0 is a bit useless since the usb connection on the PinePhone is only 2.0. «
The Gembird USB Typ-C adapter shows a blue light to indicate that it receives power from the phone, but there is no HDMI signal when connected to a HDMI monitor. We plugged it into a PinePhone running PostmarketOS.
13.7.22 update:
- plug in an usb mouse is working
- removing usb mouse and replacing by usb keyboard is working
- mouse and keyboard together not working since to little adapters
- PinePhone charges when power over usb is provided
  Pinephone (Pro) Keyboard Case for sale manubert 8 18,943 05-15-2026, 11:36 AM
Last Post: oliveira11670
  NEW pinephone keyboard case and LoRa backplate for sale ragele 0 2,872 01-12-2026, 06:09 PM
Last Post: ragele
  Replacement battery for PinePhone? j_s 9 10,410 06-03-2025, 04:19 PM
Last Post: j_s
  Searching for a PinePhone Keyboard Case RubiksCube 1 5,345 10-07-2024, 11:08 PM
  So which keyboard you suggest for the Pinephone? Peter Gamma 21 22,821 07-19-2024, 08:05 AM
Last Post: Peter Gamma
  Keyboards for the PinePhone? Peter Gamma 1 5,348 07-04-2024, 10:22 PM
  Bring the Pinephone keyboard back, it is worth it! Peter Gamma 1 5,199 07-04-2024, 07:32 AM
Heart The Pinephone keyboard offers alternative layouts Peter Gamma 0 3,088 07-04-2024, 05:40 AM
  Keyboard & 2.4G usb dongle for the Pinephone? Peter Gamma 2 4,852 06-29-2024, 09:36 PM
  Was someone able to use the Pinephone keyboard & an usb mouse at the same? Peter Gamma 4 12,569 06-26-2024, 07:11 AM
Last Post: dachalife
