Keyboard Case Redesign
This is my opinion. I own 2 original generation Pinephone v1.2b. I like the idea of the keyboard case, especially the addition of the battery. I waited on buying the keyboard case, as I didn't want to be a beta tester (I'm glad I waited). After witnessing the problems that others have experienced, I won't be purchasing the keyboard unless it is redesigned.
I think the Pinephone keyboard is a great accessory, but the POGO pin connection was a poor choice. I think it should be connected to the phone via USB and provide a USB hub.
Changing the Pinephone / Keyboard interconnection from POGO pins to USB has the following Pros & Cons:
Cons:
* A redesign of the keyboard's phone interface circuit would be required. (A USB circuit, and hopefull a hub so other USB devices could be attached)
* A redesign of the Pinephone mounting in the keyboard would be required.
* The keyboard battery level would have to be displayed on the keyboard itself.
Pros:
* No issues with poor contact with the POGO pins.
* Ability to use the Pinephone's USB port for peripherals (if a USB hub is added to the keyboard).
* No circuit redesign required of the Pinephone to prevent power feedback into keyboard if the phones USB port is used.
* The redesign of phone mount could allow for the back of the phone to remain in place including the LoRa and Fingerprint covers.
* The redesign of phone mount could allow for easier installation/removal of Pinephone from keyboard. (You could slide the phone out of the keyboard case to make/make a phone call - No spudger needed)
* No special keyboard driver to code and maintain.
Mark
pine organization has taken the path what they have taken, it has some advantages and disadvantages. at this point, argument is changing the course some way and change may not be justified enough.
i reserved this comment for the near future, but maybe i tell it now.
one pinephone could be, let's call it wide. this wide has keyboard prebuilt and it's clamshell as a vertical position. of course big battery. usb would work totally. specs would be similar to pp pro but price would be around 350 dollars.
i don't think that pine org is seriously planning next pinephone in this year (2022).
  Rii mini 4 keyboard and touchpad work over Bluetooth Peter Gamma 2 4,122 06-04-2026, 12:16 PM
Last Post: elinkser
  Pinephone (Pro) Keyboard Case for sale manubert 8 17,518 05-15-2026, 11:36 AM
Last Post: oliveira11670
  NEW pinephone keyboard case and LoRa backplate for sale ragele 0 2,176 01-12-2026, 06:09 PM
Last Post: ragele
  keyboard case charging but not typing new2pinephone 19 24,220 02-14-2025, 04:09 PM
Last Post: zltpxqhp69o2
  Searching for a PinePhone Keyboard Case RubiksCube 1 4,723 10-07-2024, 11:08 PM
  Troubleshooting Pinedio LoRa Add-on Case nickp 2 3,738 09-29-2024, 09:17 PM
Last Post: lavabrilliant
  Getting started with fingerprint scanner case lolgzs 1 4,888 09-08-2024, 04:21 AM
Last Post: mfashby
  So which keyboard you suggest for the Pinephone? Peter Gamma 21 20,390 07-19-2024, 08:05 AM
Last Post: Peter Gamma
  Bring the Pinephone keyboard back, it is worth it! Peter Gamma 1 4,602 07-04-2024, 07:32 AM
Heart The Pinephone keyboard offers alternative layouts Peter Gamma 0 2,657 07-04-2024, 05:40 AM
