Exclamation Mark on Cellular
(04-08-2022, 06:58 AM)M.A. Wrote: I'll test if I have the same problems that Chief had, just to make sure that changing the MMS settings is needed.
Hi ... I'm still having intermittent issues sending text. I still think the problem is related to 'Calls'.
Exclamation mark is back too.
Good luck.
Hmm... So is this a problem that needs to be fixed with an update?
(04-10-2022, 02:01 PM)M.A. Wrote: Hmm... So is this a problem that needs to be fixed with an update?
I'm uncertain however I suspect that it was an update that started the problem. Since I'm not the only person having this problem and numerous carriers are involved I still suspect calls update caused the issue. What I have done is allowed the "invalid" domain to remain rather than my carrier as chat isn't a high priority for me. I will continue to do updates and in time try it again with proper domain names. At this moment I have my protocol set to 3G only and I will see how that goes.
  Latest update broke my cellular 112113101098101077 1 2,282 05-05-2021, 06:41 AM
Last Post: 112113101098101077
