WiFi MAC Address on PinePhonePro
Shocked
My new one arrived today (beware UK user's there's a £70+ duty charge   Sad ).
Opened the back, removed the plastic tab off the battery, left the dip-switches all to 'On' and inserted a SIM card and then the battery.  Popped it on to charge and it powered up Big Grin  - no need to press button 5 'Power'.
Entered timezone then got taken to wifi screen where it asks me to select a wi-fi (there's no 'NONE' option) so I chose my local wifi and then was asked for a password.  No problems but my wifi has MAC filtering on, I can't connect to it unless I know the MAC address to add to the filter.
Does anybody know how I can display the MAC address of the wireless interface or how to skip the wifi option ?
I've tried swiping the screen pressing the "< WiFi" at the top right of the screen but nothing happens.  I can't find any MAC addresses on the printed paper with the phone or on the box either.
There's nothing on the WIKI either AFAICT.
Regards,
D
As a followup, I turned wifi switch off but still get the 'WiFi' page but there are no networks displayed and there is no way to go past the 'Wi-Fi' page.
Sort of sorted.
I turned off MAC filtering on my WiFi and managed to get through the setup OK.
Opened a shell and ip addr show to get the MAC address of the interface to add to the router and it's all fine now.
Takeaway to any devs reading this -
Add a 'NONE' or 'Skip' option to the WiFi configuration table.
Having to turn off a security feature to enable configuration is NOT a good plan and defeats the purpose of buying the phone in the first place.
Had a similar issue ... turned out I couldn't see the very faint skip button in the upper right corner with the protective film in place.
To find your MAC address, open a terminal window, and type "ip a" without the quotes of course, that will give you a page full of info. including your WiFi MAC address.
***   Don't be a minion in the (i)droid army   ***
Something to keep in mind is that the MAC address for the wifi may be randomized. I don't know whether this is the default or not, but you can configure it on a per-SSID basis.
  Packet injection for internal wifi chipset pinephone pro covar 1 1,310 06-30-2023, 06:45 AM
Last Post: fxc
Heart Help, I want to buy pinephonepro in hong kong miaoish 7 3,104 01-18-2023, 01:19 AM
Last Post: Keetoo
Shocked Any good reason for choosing Broadcom chip as Pinephone Pro's WiFi ? mikeb 5 3,177 09-22-2022, 05:43 AM
Last Post: linmob
  Convergence Thread (PinephonePro) magdesign 6 4,465 07-14-2022, 07:27 AM
Last Post: wibble
  PinephonePro Explorer Edition for sale, link in the post. LinuXmarksTheSpot 0 923 05-29-2022, 12:15 PM
Last Post: LinuXmarksTheSpot
  New PinePhone died after first WiFi setup phero 8 4,992 03-06-2022, 06:05 AM
Last Post: phero
