calls and voice mail blocked
Question
Hello pinephone thread,
I'll probably be searching on that problem for a while, but I case someone can help, I'll post here first.
After having using a mmcli command that was meant to reboot the modem manually, I lost the ability to make or receive call. This is, what I suspect to be the cause, but it can be due to other factors, like hardware failure or carrier blacklisting me.
Among important symptoms that I can mentions are:
- I do can send/receive sms
- But I can't call/receive calls.
- Cell tower is fully detected.
- When my sim card is inserted in pinephone, people who try to call me, are unable to leave a message on my voice mail box, as if my carrier was thinking that my pinephone was answering, thus not activating the voice mail.
- On the other hand, when sim card is inserted in android, I can call/receive call, and people can leave messages on voice mail box.
- The problem persist after installing a fresh distro, as well as an upgraded one.
I unfortunately don't have an answer for you, but it might be worth asking in the Matrix chats as you might get a quicker answer.
Here is the Mobian one, which is quite active but not so active that it feels like yelling in to a void.
https://matrix.to/#/#mobian:matrix.org
What was the exact command you entered? As it sounds like that will be needed to reverse this damage.
Cheers,
TRS-80
Protocols, not Platforms
Could it be related to VoLTE support status for your carrier? More detail about VoLTE and test commands in this thread:
https://forum.pine64.org/showthread.php?tid=12560
(02-22-2022, 07:15 PM)TRS-80 Wrote: What was the exact command you entered?  As it sounds like that will be needed to reverse this damage.
Since I thought that reinstalling a new image would resolve the problem, didn't think it could be useful to keep track of the command that caused it. Now, I learn by my mistake: some modifications are stored permanently in the modem, rather than on the sd card.
The command probably was one of those four:
mmcli -m any --command='AT+CFUN=1,1'
sudo systemctl restart eg25-manager.service
mmcli -m any --reset
There's a bug in my pinephone,some sms show up only after reboot. I thought I could just restart the modem to get those stuck sms, instead of rebooting.
Furthermore, after having gone through the mobian troubleshooting page, I succeeded bringing back the 3G cell mode, but the step toward re-enabling the voLTE 4G remains a mystery. I suspect that my carrier's system has to do some sort of digital handshake with the pinephone first.
See the post #4 above to re-enable VoLTE
Thumbs Up
I found the solution, and I'll explain it.
I did all the steps in the link given in the link at comment #4.
Since my carrier (Bell) isn't it the list, I've tried those provided, one by one, until I found one that worked.
+QMBNCFG: "List",2,0,0,"hVoLTE-Verizon",0x05010141,202004091
I hope it will help people who are trying to enable voLTE calls with Bell.
  No calls in or out on beta IsaiahSp 0 676 09-28-2023, 10:44 PM
Last Post: IsaiahSp
  No calls on Pine Phone Beta convergence edition polypode 1 1,172 03-06-2023, 08:04 PM
Last Post: rocket2nfinity
  I cannot call or receive calls aka0kuro 6 3,066 01-13-2023, 05:31 PM
Last Post: alaraajavamma
  Any UK Pinephone users making telephone calls? GrapeJuice 4 3,100 01-24-2022, 04:37 PM
Last Post: dukla2000
  New screen, now cant make calls bug1 2 2,899 03-15-2021, 02:02 AM
Last Post: bug1
  Low Volume Making Calls (Ubuntu Touch) PineFuture 3 3,933 08-04-2020, 11:47 AM
