Error - megapixels not opening
Unfortunately,
sudo dpkg-reconfigure megapixels
did not do the trick on my phone.
Going
sudo apt purge megapixels
and reinstalling from http://ftp.debian.org/debian/pool/main/m/megapixels/ did not work either; simply because I lacked the skills or a step by step guide, so I only got error messages.
So I did not know anything better than to
sudo apt install megapixels
What should I say? It works again.
(03-03-2022, 10:10 AM)Anna Wrote: Unfortunately,
Going
I did no changes on mine, it sometimes works sometimes not.
I have it working again, but it locks up if it decodes a QR code.
(03-16-2022, 02:01 AM)biketool Wrote: I have it working again, but it locks up if it decodes a QR code.
It should work anew with the next minor version of GTK (4.6.2).
(03-18-2022, 06:01 AM)anonymous Wrote: It should work anew with the next minor version of GTK (4.6.2).
Any idea when that GTK update will be coming down the wire? I just updated my Mobian installation and Megapixels is still screwed up. Sometimes it works and sometimes it doesn't. When it does run, a QR code will crash it.  I very rarely use the camera but have found it useful on a couple of occasions so it would be nice for this to work again.
Attempting to run megapixels from the command line yields the following:
Gdk-WARNING **: 14:24:24.823: gdk_gl_context_set_required_version - GL context versions less than 3.2 are not supported.
Initialized OpenGL 2.1
Gsk:ERROR:../../../gsk/gl/gskglcommandqueue.c:1266:gsk_gl_command_queue_create_render_target: assertion failed (glCheckFramebufferStatus (GL_FRAMEBUFFER) == GL_FRAMEBUFFER_COMPLETE): (0x00008cd6 == 0x00008cd5)
Bail out! Gsk:ERROR:../../../gsk/gl/gskglcommandqueue.c:1266:gsk_gl_command_queue_create_render_target: assertion failed (glCheckFramebufferStatus (GL_FRAMEBUFFER) == GL_FRAMEBUFFER_COMPLETE): (0x00008cd6 == 0x00008cd5)
Aborted
With the latest updates on bookworm the necessary libs are shipped, see https://gitlab.com/postmarketOS/megapixe..._889450659
(03-25-2022, 12:31 PM)jsch Wrote: With the latest updates on bookworm the necessary libs are shipped, see https://gitlab.com/postmarketOS/megapixe..._889450659
Thanks, I'll run an update and see how it works out!
Results: Did the update but no joy, Megapixels still crashes on the same error. Same after running apt purge megapixels followed by apt install megapixels.
Another update: Taking a hint from a previous post here I ran dkpg-reconfigure megapixels and now it works, including recognizing QR codes and offering to launch a web browser if it contains a URL.
just a note :
In the early Mobian days it was mentioned they 'May eventually return to "Pin Hole" as their camera app'
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
your favorite OS Team
  [Megapixels] Flash strobe, pictures viewer and MPCamera error 22 freelectro 1 1,124 08-30-2023, 03:59 AM
Last Post: karensather
  Megapixels doesn't work Glenn 4 2,801 08-28-2022, 03:19 PM
Last Post: vortex
  Megapixels and Pinhole Zebulon Walton 0 914 06-15-2022, 04:53 PM
  Flatpak error during apt update user641 0 1,148 02-14-2022, 08:35 AM
Last Post: user641
  Waydroid error: not using Wayland. But I am! quixote 7 6,704 01-09-2022, 02:47 PM
Last Post: jsch
  Installed Apps not opening mmd604 5 4,003 10-08-2021, 09:29 AM
Last Post: ragreenburg
  Enter disk decryption passphrase error healthyliving101 3 3,027 09-07-2021, 12:21 PM
Last Post: Fenellakw
  Video playback error (Totem/Videos) Zebulon Walton 0 1,083 08-19-2021, 05:37 PM
  Unable to play videos ("bitstream error") pietenpol 1 2,155 06-14-2021, 07:58 AM
Last Post: Gribouille
  How to use Megapixels and QR codes? Zebulon Walton 3 3,558 05-06-2021, 12:20 AM
Last Post: awaittrot
