Pinephone keyboard needs pressure
Pinephone Keyboard doesnt work unless I push to backcover or display in place where pogo pins are. Do you have annyone same experience? How did you fix it? I am sure that phone is fully in case, I trided multiple times to put out and in, no difference
Yes' this is the same for me. I sent email to Pine64 support and they responded timely. Still working on a resolution.
https://wiki.pine64.org/wiki/PinePhone_(...er_contact
(02-24-2022, 07:43 AM)wibble Wrote: https://wiki.pine64.org/wiki/PinePhone_(...er_contact
Thanks! The link helped, at least for now. I realized shim need not be metallic, which was my biggest fear. I used slightly stiff card cut to size to prop up the contacts so that the connection was better. It has resolved the issue for me for now. Will be interesting to see how long it lasts. Of course, it will be welcomed if a paper shim is all that is needed.
@terarmot Did your keyboard work in part, or not at all?
I got a keyboard yesterday & am having trouble with it.  It partially works. It snaps into place & the phone recognizes the battery, but the keypad doesn't work.  Before I go shimming things I wonder if that's still the solution.
any reply is appreciated
  Rii mini 4 keyboard and touchpad work over Bluetooth Peter Gamma 3 5,963 10-15-2026, 08:04 AM
Last Post: Flymoon
  Pinephone (Pro) Keyboard Case for sale manubert 8 19,659 05-15-2026, 11:36 AM
Last Post: oliveira11670
  NEW pinephone keyboard case and LoRa backplate for sale ragele 0 3,320 01-12-2026, 06:09 PM
Last Post: ragele
  Replacement battery for PinePhone? j_s 9 11,295 06-03-2025, 04:19 PM
Last Post: j_s
  keyboard case charging but not typing new2pinephone 19 27,770 02-14-2025, 04:09 PM
Last Post: zltpxqhp69o2
  Searching for a PinePhone Keyboard Case RubiksCube 1 5,619 10-07-2024, 11:08 PM
  So which keyboard you suggest for the Pinephone? Peter Gamma 21 24,204 07-19-2024, 08:05 AM
Last Post: Peter Gamma
  Keyboards for the PinePhone? Peter Gamma 1 5,596 07-04-2024, 10:22 PM
  Bring the Pinephone keyboard back, it is worth it! Peter Gamma 1 5,463 07-04-2024, 07:32 AM
Heart The Pinephone keyboard offers alternative layouts Peter Gamma 0 3,295 07-04-2024, 05:40 AM
