Pinephone pro seems to have died overnight....
Received my Explorer Edition yesterday. Booted it, played around. Everything seemed fine, Discover seemed broken (default KDE Manjaro). Shut it down, tried mounting it in the pinephone keyboard, never got the keyboard working, planned on trying the pogo shim this weekend. Shut it down, back into "phone mode" played around some more. Let it charge, then unplugged it and left it on my desk for the night.
This morning, wouldn't start. Plugged in, off to work. Still no boot. Removed battery, monkeyed around with various attempts at powering up. I don't get a vibration or anything on plugging it in as described charging indicator (pine64.org) .
Next steps for troubleshooting?
(01-28-2022, 06:27 PM)projectcato Wrote: Received my Explorer Edition yesterday. Booted it, played around. Everything seemed fine, Discover seemed broken (default KDE Manjaro). Shut it down, tried mounting it in the pinephone keyboard, never got the keyboard working, planned on trying the pogo shim this weekend. Shut it down, back into "phone mode" played around some more. Let it charge, then unplugged it and left it on my desk for the night.
I didn't notice this before: PinePhone Pro - PINE64 (blue box):
Quote:If the battery is fully drained U-Boot might fail to boot any installed operating system on the eMMC and microSD card due to a bug.
If that's the case please start your phone in Maskrom mode and let it charge in that for a few hours. To do that:
  • Remove any microSD card from the phone
  • Hold the "RE" button underneath the back cover of your Explorer Edition (or shorting the bypass contact points on the Developer Edition)
  • Connect the phone to an USB port of a computer, while still holding the button
  • Check if the phone in Maskrom mode appears in the output of the Linux command
    lsusb
     on the computer (if the device disappears again please use a different cable)
  • Let the phone charge for multiple hours.
Can confirm this worked for me, got up to about ~30% charge by the time I got impatient and tested. Note, after this procedure, the phone only booted after another battery remove / reinstall.
    lsusb
I've tried this process doggedly and repeatedly, using various cables, etc., but still have a dead PPP.
Any other suggestions?
I also had a dead PPP this morning.
Just got it on last Thursday and started using it a bit this weekend, just to stream some music, but was completely dead this morning. It started with bootloops for breakfast. I could see that it was reaching a certain point in the boot, then dying. I have the USB charge station with display and it was helpful to see that the phone wasn't taking a charge except for the first few seconds while it tried to boot, but wasn't enough for it to charge the battery, then died. Repeat. It did this until the battery was too low to even power on the phone.
I resolved it by putting the battery into my original PinePhone and got it to charge on there. That allowed me to get up to about 15% charge, then was able to get the PPP to boot past where it was failing before and started charging normally.
    lsusb
I'm in the same boat. My phone doesn't actually leave Mask ROM mode. I don't have to press the reset button when I connect to my desktop and the battery doesn't need to be installed.
I'm trying to see how to get out of DFU mode Smile
Okay, I continue to end up in DFU mode.
I have to leave the phone to charge for hours in DFU before it recovers: it doesn't charge anywhere near as fast as it does (from the same computer port) when running normally.
I'll poke around with the phone for a bit. Still using Manjaro plasma, but I'm about to switch because I'm really unhappy with it from a basic stability standpoint. Battery life seems fine, but if I leave it unplugged overnight, I'm back to a DFU recovery. Left on the charger overnight, by three nights in, I'm DFU anyway. Completely baffled as to why.
  PinePhone Pro disable Volume Buttons when malfunctioning ArchBene 1 1,853 07-01-2026, 10:53 AM
Last Post: FR_IV
  Fix Bricked SPI Flash, Pinephone Pro FR_IV 0 311 06-27-2026, 05:00 PM
Last Post: FR_IV
  performance wise which iphone does the pinephone pro compare to? heocb 2 1,834 01-24-2026, 01:01 PM
Last Post: heocb
Exclamation Pinephone pro stuck while booting Supervisor 3 3,147 10-07-2025, 02:46 PM
Last Post: Supervisor
Question Are there plannes to create a new and more powerfull PinePhone Pro? Nima0908 5 13,466 08-18-2025, 04:12 AM
  Pinephone pro packet injection for internal wifi chipset covar 3 5,590 07-02-2025, 02:03 PM
  RTKLIB PinePhone Pro GPS jlaba 1 2,174 05-02-2025, 12:43 AM
  PinePhone Pro Explorer's edition Qualcomm modem recovery shifras 11 12,830 02-28-2025, 07:03 AM
Last Post: tensa1000
  PinePhone Pro EDL boot by shorting contacts ozkenlc 3 5,769 09-18-2024, 04:59 AM
  PinePhone's LED is blinking, but doesn't start zvavybir 0 2,021 09-06-2024, 02:39 AM
Last Post: zvavybir
