M.2 SSD not visible when connected via PCI-e board
Question
Hi all,
I am having trouble using an M.2 2280 SSD with my Rockpro64. The SSD is attached via a PCI-e card, but the drive does not register with the computer. When I run `lsblk`, the 1TB drive does not appear.
I have double checked the SSD is functional by plugging it into another laptop (using an external SSD casing). I have also tried two different OS's on the Rockpro, and two different PCI-e cards.
My setup is as follows
  • new ROCKPRO64
  • ROCKPro64 PCI-e X4 to M.2/NGFF NVMe SSD Interface Card
  • also tried using another PCI-e card, with no success
  • WD Blue 3D NAND SATA M.2 2280 SSD, 1TB
  • 12V 5A power supply
  • OS 1: manjaro-xfce-21.2.1-220103-linux515.iso
  • OS 2: RoninOS (Manjaro fork designed for Rockpro64): https://wiki.ronindojo.io/en/gui-setup/step1
My only ideas are that:
  • I have missed out something in the hardware setup that would allow the PCI-e board to function properly
  • The PCI-e port/reader on the Rockpro motherboard is faulty
Any advice or help is much appreciated.
Have you confirmed the NVMe drive type is PCIe and not SATA?
(01-17-2022, 04:17 PM)jimh227 Wrote: ...
Please be aware that the Pine64 SSD interface card is intended for use with NVMe devices. These can be identified by the fact they have a single (Key M) notch, e.g. the WD Black devices.  While M2/NGFF SATA devices (with a Key B notch, typically have Key M as well) will physically fit, they will not work. e.g. WD Blue devices.
@tophneal @dukla2000 Thank you both for the replies. You're right, the SSD is SATA. I thought if it had the right form factor, it would work.
Is there an adaptor for the Rockpro that will allow me to use this drive? Or do I need to get a different SSD?
Thanks again
(01-18-2022, 03:09 PM)jimh227 Wrote: @tophneal @dukla2000 Thank you both for the replies. You're right, the SSD is SATA. I thought if it had the right form factor, it would work.
Thanks again
I'm not 100% sure but this looks very similar in size to the m.2 NVMe card. It also has a second regular SATA controller. Would probably try to find out about the controller chip and whether is is supported by the linux kernel (to its credit, the kernel covers a fantastic array of drive controllers).
it doesn't get happy
it doesn't get sad
it just runs programs
  How do you connect PWM fan (3/4 pins) to this board (2 pin fan connector)? aleksei 3 8,092 11-19-2020, 04:35 PM
Last Post: Gienek
  Won't boot with 2.5GBe PCIe adaptor connected voltagex 1 2,933 10-20-2020, 12:22 PM
Last Post: xmixahlx
  Getting 12v from the board domih 2 3,856 06-14-2019, 08:02 PM
Last Post: domih
  PCI-E Graphics Board Possible? Diesel141 1 2,666 04-23-2019, 12:13 AM
Last Post: Bullet64
  Discovered issues with PCIe NVMe & GPU Load in desktop 4.4.174 causing board lockup axelf 0 1,987 04-08-2019, 03:51 PM
Last Post: axelf
  Defect board? buskmann 2 3,503 02-16-2019, 12:27 PM
Last Post: buskmann
