Basic Examples code for Androdid I/O pins .??
Wink
i Think i would be really helpfull if we can get sample codes to use the I/O pins on android and linux as well
so we can manage to build whatever we want from the botom up and using the capabilities of the board it self
such as
i2c Serial
Spi
UART
GPIO
and if is capable of. PWM as well
By. Zoidiano0!
Installed:
LAMP: Linux , Apache2.4 , Mariadb, phpMyadmin, PHP5
Java 8 arm by oracle
Netbeans 8.1
chromium (uses way toooo much Ram)
Pine64 Head Unit Project.!
(01-21-2016, 09:02 PM)Zoidiano0 Wrote: i Think i would be really helpfull if we can get sample codes to use the I/O pins on android and linux as well
such as
i2c Serial
Spi
UART
GPIO
Good suggestion, we will look into this.
  Code::Blocks IDE compilation manual Artyom 3 8,417 08-01-2016, 12:37 AM
Last Post: Artyom
