PinePhone Keyboard on other phone/over USB
I recently got a Fairphone 4 but I'd really like to use that keyboard.
Adapting the physical space for the phone shouldn't be hard, considering that I have a 3D printer. I have done similar work before.
Obviously, though, I wouldn't be able to use the original connector, and probably not even the original connection protocol, since I can only connect USB to the Fairphone.
Is it possible to connect the keyboard using USB? I've seen in some video, that (at least an older preproduction version of the keyboard) has an internal USB connector. Does this connector send HID? If not by default, would it be possible for me to modify the firmware to output HID over USB?
Now, that Linux kernel 6.1 supports the keyboard, there should be much better chances to use the keyboard for other devices, Let's see and search ...
  Rii mini 4 keyboard and touchpad work over Bluetooth Peter Gamma 2 4,188 06-04-2026, 12:16 PM
Last Post: elinkser
  Pinephone (Pro) Keyboard Case for sale manubert 8 17,577 05-15-2026, 11:36 AM
Last Post: oliveira11670
  NEW pinephone keyboard case and LoRa backplate for sale ragele 0 2,212 01-12-2026, 06:09 PM
Last Post: ragele
  Replacement battery for PinePhone? j_s 9 8,734 06-03-2025, 04:19 PM
Last Post: j_s
  keyboard case charging but not typing new2pinephone 19 24,286 02-14-2025, 04:09 PM
Last Post: zltpxqhp69o2
  Searching for a PinePhone Keyboard Case RubiksCube 1 4,747 10-07-2024, 11:08 PM
  So which keyboard you suggest for the Pinephone? Peter Gamma 21 20,488 07-19-2024, 08:05 AM
Last Post: Peter Gamma
  Keyboards for the PinePhone? Peter Gamma 1 4,814 07-04-2024, 10:22 PM
  Bring the Pinephone keyboard back, it is worth it! Peter Gamma 1 4,629 07-04-2024, 07:32 AM
Heart The Pinephone keyboard offers alternative layouts Peter Gamma 0 2,682 07-04-2024, 05:40 AM
