Mobile internet via cellular network mostly not working
(12-04-2021, 08:27 AM)Anna Wrote: For some time now (since Bookworm? Or only a few weeks? I actually don't know) I usually don't have internet access via the mobile network.
Sometimes it works, mostly it does not. A restart usually helps, but of course that's not what you want to do when you need to quickly look something up or when you or wait for a Signal/Telegram message while on the move. The problem occurs with two different providers.
Is there anything I can do?
I noticed tonight that my 4G data is no longer working. The 4G connection seems to be up and there is plenty of data on my plan. Rebooting and updating have not helped.
Prior to this 4G data has been pretty solid with only the occasional reboot to get it up and running again.
Edit ; I will try the resolvconf fix above as the modem is reported to be working but nothing resolves.
RE: Mobile internet via cellular network mostly not working - by grump_fiddle_reinstall - 02-28-2022, 12:40 PM
Exclamation The internal speaker stops working anonymous 6 1,299 01-17-2024, 05:53 PM
Last Post: anonymous
  APN settings not working with new operator SIM card user641 1 1,104 03-01-2023, 04:43 PM
  Possible Solution for Microphone Not Working Ferriah 0 1,005 02-13-2023, 01:09 PM
Last Post: Ferriah
  Not connecting to cellular network car46999 18 7,982 01-30-2023, 12:06 AM
Last Post: car46999
  Block firefix-esr-mobile-config from (re)installing itself grump_fiddle_reinstall 3 1,689 01-07-2023, 09:36 AM
Last Post: dcarvil
Exclamation No modems were found: No mobile data, no 2G anonymous 2 1,483 12-26-2022, 06:46 PM
  very slow processing of MMS received via Ting (T-Mobile) treebeard 6 2,743 12-01-2022, 09:18 AM
Last Post: traut
  Squeekboard stopped working Zebulon Walton 2 1,273 11-24-2022, 08:41 PM
  need help with downgradin network-manager Ferriah 0 690 11-07-2022, 04:51 PM
Last Post: Ferriah
  DNS Problems with Mobile Data arno_nuehm 29 17,804 10-29-2022, 09:16 AM
Last Post: treebeard
