Changed pin to blank and can't get into phone now.
Hi all,
I got tired of putting my pin into the phone so I changed it to blank in settings.  I tried opening the phone up and now everything I enter (including blank) results in Wrong PIN.  What's the next step?
Thanks!
Plug a keyboard into the phone, hit Ctrl+Alt+F2, login as root and change your password.
Just tried that. I don’t see any response to the keystroke. Do I need to plug into a screen or should the phone display a terminal?
Sent from my iPhone using Tapatalk
Hmm. Okay. I was able to get a terminal with ctrl alt F3. Tried logging in as root with:
- my old pin
- blank
- 123456
But none work.
Is it time to reinstall the OS?
I would just re-flash,
It is so easy with the Pinephone, especially if your are using an sd card.
Hopefully you do not have a lot of stuff saved on the existing installation.....
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
your favorite OS Team
Quote:- my old pin
- blank
- 123456
root's password won't be any of those. I'm assuming because you tried 123456 that you're using Arch. root's password by default is "root".
You can also boot the jumpdrive image and mount the eMMC partition over USB, then you can manually edit /etc/shadow.
https://github.com/dreemurrs-embedded/Jumpdrive
Generate a new password with:
openssl passwd -6
and copy it instead of the current one to /etc/shadow
my website: https://xnux.eu
  Looking for the "non-phone" OS wakyct 7 1,274 03-14-2024, 03:51 AM
Last Post: MTXP
  Writing apps/programs for pine phone katesfb 7 5,073 03-11-2024, 10:42 PM
Last Post: Emelia525
  How To Access the Pine Phone Auxillary microSD Without Removing Card pinephoneuser22 2 949 01-09-2024, 07:02 PM
Last Post: britelite
  Mobian PIN changed after update! Mwo87 21 17,767 12-02-2023, 11:53 PM
Last Post: Karrenbrady
  Can the Pine Phone be serviced and updated remotely? profileyourcity 3 1,109 10-02-2023, 05:19 PM
  UBports on pine phone? robb777 16 3,808 09-01-2023, 04:26 AM
Last Post: gregb49
  US Cell Phone Service Providers with prices and phone numbers - UPDATED jovval 0 734 07-01-2023, 01:25 AM
Last Post: jovval
  Loving my pine phone after about a year of not undata 0 711 05-11-2023, 02:23 PM
Last Post: undata
  New Phone Opening Issues LuluFrance 5 2,190 03-15-2023, 05:33 AM
Last Post: anonymous
  pine phone external speaker AnAbolitionist 9 3,446 02-08-2023, 01:11 AM
Last Post: robb777
