Phone stuck in a login loop
Sad
I received this phone on Sept 2, had a problem with it from get-go. Unless it is connected to a charger it sticks in a login loop. That is: enter password, accepted, display for about 5 seconds, enter password etc, etc. etc..
While the phone was on the charger I tried a software update as suggested. That kept crashing with libcanbera 0.30+2+ unmet dependencies. After a lot of searching I discovered how to update from the terminal with Pacman (always thought that was an arcade game from the ‘70s). That crashed and could not be updated due to locked files which had to be removed using the terminal. This happened 3 or 4 times.
With the last update try I left it over night on the charger.
Update success: but: It is still stuck in the login loop.
Is this PinePhone quality control or did I just get a piece of junk?
Yes, we all got a "piece of junk" if you like to say it so.
Didn't you read all the disclaimers? Especially the software... For developers and early adopters with certain Linux knowledge...
It is always good to search the forum for similar problems Wink
Eg this one: https://forum.pine64.org/showthread.php?tid=14684
Or: https://forum.pine64.org/showthread.php?tid=14172
  Looking for the "non-phone" OS wakyct 7 1,262 03-14-2024, 03:51 AM
Last Post: MTXP
  Writing apps/programs for pine phone katesfb 7 5,066 03-11-2024, 10:42 PM
Last Post: Emelia525
  How To Access the Pine Phone Auxillary microSD Without Removing Card pinephoneuser22 2 944 01-09-2024, 07:02 PM
Last Post: britelite
  Can the Pine Phone be serviced and updated remotely? profileyourcity 3 1,105 10-02-2023, 05:19 PM
  UBports on pine phone? robb777 16 3,789 09-01-2023, 04:26 AM
Last Post: gregb49
  Boot screen stuck at 'K' because of firmware deleted. poundantisec 9 5,255 08-28-2023, 11:38 AM
Last Post: fxc
  US Cell Phone Service Providers with prices and phone numbers - UPDATED jovval 0 733 07-01-2023, 01:25 AM
Last Post: jovval
  Loving my pine phone after about a year of not undata 0 709 05-11-2023, 02:23 PM
Last Post: undata
  New Phone Opening Issues LuluFrance 5 2,188 03-15-2023, 05:33 AM
Last Post: anonymous
  pine phone external speaker AnAbolitionist 9 3,440 02-08-2023, 01:11 AM
Last Post: robb777
