Soldering eMMC to SoEdge
I bought a few of the SoEdge parts and I wanted to get them booted off soldered eMMC. I did order some eMMCs as well but they havnt arrived. I have a bunch of eMMC that match the footprint and probably the pinout. Im pretty good at solder but is there anything I should know before doing this so I dont kill the module.
- checking pinout to make sure it matches
- correctly solder
- seems they use FORSEE eMMC, I dont have those parts but I have something similar.
How about software interfaces? Are they pretty similar across different eMMC parts?
Any help would be great! Ill post my results.
(08-26-2021, 11:37 AM)einthecorgi2 Wrote: I bought a few of the SoEdge parts and I wanted to get them booted off soldered eMMC. I did order some eMMCs as well but they havnt arrived. I have a bunch of eMMC that match the footprint and probably the pinout. Im pretty good at solder but is there anything I should know before doing this so I dont kill the module.
- correctly solder
If you manage to solder properly, it will work. Most of the eMMC that have same pin count are pin to pin compatible.
  SoEdge v. SoPine ian-s-mcb 2 4,917 12-02-2020, 08:40 PM
Last Post: ian-s-mcb
