No updates after upgrade?
Debian GNU/Linux 11 (bullseye)
64-bit
GNOME 3.38.5
Wayland
After trying out some things which were hardly reversible I reinstalled mobian about a week ago with an image from images.mobian-project.org. Since installing, I did not get a single update although the image seems to be from may 2021.
I tried it using the software app, that always throws an error: Failed to update metadata for lvfs. After running
fwupdmgr --force refresh
in the terminal, the error isn't thrown any more and the software app tells me that everything is up to date.
I tried in the terminal running
apt update
which also tells me that everything is up to date.
apt-upgrade
gives me 0 updated, 0 new installed, 0 to remove and 0 not updated.
Why I doubt that is is correct is because before the reinstallation it felt like receiving updates  regularly.
Does anybody have a clue if I might be right? Thank you!
See:
https://blog.mobian-project.org/posts/20...e-release/
Thanks for that info.
Today is August 26, 2021
I downloaded the Nightly release marked August 26 last night.
It is running on an sd card in one of my PMOS Convergent phones.
After doing the normal first boot stuff, fill-in all the blanks, etc... It did a rather large download of 'updates'.
I really like to see what and how the newest software is coming along, but my daily driver is running a month old copy of Mobian.
I do regular updates on that phone as well. But there are differences between an updated OS and a fresh install.
I showed that previously, where the fresh install and the updated install were running on 2 identical PMOS phones setting next to each other.
The fresh install was using 0.7 watts less than the updated installation.
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
your favorite OS Team
  No volume control after latest updates Zebulon Walton 19 7,434 09-08-2023, 08:28 AM
Last Post: jessencan
  Mobian boot failed with zstd message after upgrade. Mahgue 0 668 09-01-2023, 11:29 AM
Last Post: Mahgue
  Problem with updates: Repository 'Debian bookworm' changed its 'non-free component' Anna 7 2,778 08-31-2023, 12:38 PM
Last Post: vusra
  Haven't seen updates in a while Zebulon Walton 3 1,334 06-24-2023, 04:29 PM
Wink Pinephone lost graphic during mobian system upgrade cmpin 4 2,294 03-01-2023, 04:45 PM
Last Post: anonymous
  No boot after upgrade: vibration, red LED, then 2 vibrations and yellow LED 3x5co 1 1,036 01-04-2023, 06:46 PM
Last Post: 3x5co
  Receive MMS fails after Nov 27 upgrade treebeard 17 6,291 12-12-2022, 05:09 AM
  [Fixed] Phosh crashes frequently after latest updates arno_nuehm 20 9,218 10-14-2022, 05:38 PM
Last Post: Krafter
  Dist-upgrade and Chatty vs Gnome-Contacts biketool 9 4,251 09-30-2022, 08:53 PM
Last Post: treebeard
  Modem Firmware Upgrade - Modem Busy - USB Issues biketool 10 5,019 09-23-2022, 05:15 AM
