PINEBOOK Pro USB-C Docking Deck compatibility
Hello people, just saw on twitter the new PINEBOOK Pro USB-C Docking Deck.
I have 2 question though:
  1. Does this USB-C dock work with any USB-C/Thunderbolt 3 port say MSi notebook?
  2. In my consideration the cable is too short. Some notebooks have the USB-C on the back of the computer so you need at least half a meter to put the dock properly on the side, otherwise you have to buy an extension.
https://19216811.cam/ https://1921681001.id/
Right from your link, "The Docking Deck can only function with the PINEBOOK Pro Laptop".
Any other use is at your own means. Buy an extension if you need one. Else buy the dock you want.
:wq
[ SRA accepts you ]
  [Pinebook Pro] Where to buy a new TFT and how to replace it? openbsd98324 0 478 09-30-2023, 02:37 PM
Last Post: openbsd98324
  Pinebook Pro with RK3588? tantamount 28 6,360 07-13-2023, 04:06 PM
  The power of the Star64 vs Pinebook Pro/RockPro64 Starfall 1 1,159 04-17-2023, 05:00 AM
Last Post: lkoini
  Could an arm based pine 64 smaller than normal to go with the pinebook zanewiller 1 1,359 07-12-2022, 03:33 AM
Last Post: Weatherburn
Lightbulb NUT (Network UPS Tools) compatibility Scary Guy 0 861 04-22-2022, 08:12 PM
Last Post: Scary Guy
  Could an arm based pine 64 smaller than expected to go with the pinebook zanewiller 1 1,490 04-16-2022, 07:17 AM
Last Post: jiyong
Star Very Lightly Used PineBook Pro ragnarlothbrok64 4 3,174 01-21-2022, 02:36 PM
Last Post: sascha
  Buy a Pinebook kaizmoto1489 3 3,780 07-14-2021, 10:08 AM
Last Post: poVoq
  Pinebook Pro has become dead, no lights? JohnKarpenter 3 3,606 07-01-2021, 12:57 AM
Last Post: TfromTexas
  Pinebook Pro audio recording with Jack rfm83 0 1,487 05-15-2021, 05:31 PM
Last Post: rfm83
