Pure Maps GPS on Pinephone Mobian
OSM Scout Server and Pure Maps were pretty easy to install via flathub. Just open the links in a browser, tap install and open with the software app. It takes a while, but works a charm.
OSM Scout Server for offline maps: https://www.flathub.org/apps/details/io....coutServer
Pure Maps navigation and maps UI: https://www.flathub.org/apps/details/io....s.PureMaps
My issue is that I can't seem to get Pure Maps to use my GPS data. It has Online, Offline, and Mixed profiles. Ideally I would completely avoid using network location tracking and only use the GPS. This is both for privacy reasons but also because the VPN on my phone throws the network tracking completely off. I tried digging around to see if there was something I had to configure on the modem or some such, but I don't know very much about it and couldn't find any straight forward manner of getting the GPS working with Pure Maps or even gnome maps. I am open to using a different interface for navigation. If someone has the GPS working with a different application, I'm willing to switch.
Hopefully the 'Pure' maps will eventually work on the Mobian Pine phones...
All the other GPS app's rely on Geo-locate, which is based on using Google support.
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
your favorite OS Team
(08-02-2021, 05:40 PM)bcnaz Wrote: Hopefully the 'Pure'  maps will eventually work on the Mobian Pine phones...
No Mozilla geolocation option by playing with .conf files?
getting location data from the GPS is very difficult, you have to wait, be in open space and be lucky, they say that it has to do with the small antenna and they connect an external antenna with an amplifier, have a look at this thread to understand what happens with GPS
https://forum.pine64.org/showthread.php?tid=14114
  bookworm vs trixie discussion for mobian in pinephone regular. zetabeta 21 2,146 1 hour ago
Last Post: anonymous
  Mobian repository status henrythemouse 16 8,828 04-10-2024, 10:02 AM
Last Post: diederik
  cant verify mobian image at website gnugpg penguins_rule 0 140 03-18-2024, 08:54 PM
Last Post: penguins_rule
  unofficial kali linux for pinephone help needed pinesmell 5 3,664 01-08-2024, 02:50 PM
Last Post: ERPlegend
  PureMaps and OSM Scout Server maps download biketool 6 2,620 01-08-2024, 04:11 AM
Last Post: vusra
  mobian installed to eMMC - how to install tow-boot grump_fiddle_reinstall 6 2,022 11-22-2023, 11:46 AM
Last Post: aLoop100o
  What actions needed to keep on mobian testing user641 3 1,840 09-05-2023, 06:44 AM
  Mobian boot failed with zstd message after upgrade. Mahgue 0 643 09-01-2023, 11:29 AM
Last Post: Mahgue
  how to update mobian over tor vusra 13 6,944 07-09-2023, 08:57 PM
Last Post: vusra
  opensnitch outbound firewall now works on mobian vusra 2 1,911 07-09-2023, 01:37 AM
Last Post: vusra
