Android + battery
Hi there,
Is it possible to configure Pine's behavior when it's powered with a battery?
Mine board turns off a usb port (maybe it even turns off ethernet can't check it exactly without working mouse Smile ).
Dzmitry
------------------- up ---------------------------
(06-22-2016, 02:02 AM)dulasu Wrote: ------------------- up ---------------------------
I can't replicate your results on a pure linux build. On a longsleep-derived debian linux on the pine, when I started the pine from battery, and plugged in a flash drive, it powered up and I was able to mount it and view it's contents. When I plugged in a USB-powered USBHDD, the pine64 shut down (which didn't surprise me... it got a bit of a fright!). If I powered up the pine from the USB connector, and plugged in the USBHDD whilst the pine was being externally powered, I could disconnect the battery then and the USBHDD was still accessible. It was just that startup surge, and possibly a battery that is on it's last legs...
As far as if you ethernet is working, you should be able to see the green and yellow lights come on the connector if that is powered up and it is pluged into a switch or router.
Hopefully someone who uses an android image will be able to comment more on their luck.
  Android 6.0 Tablet and TV (release candidate, maintained) ayufan 228 389,874 12-29-2020, 01:13 AM
Last Post: firmwarefile
Shocked Remote for Android? liodra 18 29,836 12-23-2020, 06:11 AM
Last Post: Learnincurve
  Adding an accelerometer to Android modsbyus 11 16,895 11-02-2020, 08:12 PM
Last Post: Little_Johnny
  Android Things OS dqvsra 2 7,008 12-03-2019, 09:52 AM
Last Post: hangglider
  Is there another link for Android images? Maalth 3 7,083 10-10-2019, 07:57 AM
Question Android SDK Oreo NGC6691 2 5,633 07-15-2019, 08:29 PM
Last Post: dazza5000
  Putting Android 9 RockPro64 source into easier to manage repositories dazza5000 0 3,356 07-15-2019, 08:29 PM
  Android 5.1.1 TV (old-stable, no longer maintained) ayufan 194 259,753 03-12-2019, 04:53 PM
Last Post: neosapien
  Issues with SD Card and Running Android Twistedx 0 3,560 02-26-2019, 11:58 AM
Last Post: Twistedx
  Android 7.1 (PINE A64(+)) pineadmin 59 105,693 02-10-2019, 07:44 PM
Last Post: mmmarcus
