Samsung Galaxy S4 Salvage?
I recently upgraded phones as my S4's screen gave out. I was wondering if there's anything I can salvage from my Samsung Galaxy S4 and repurpose for use on my Pine board (whenever it actually arrives)? I'm new to this kind of thing and plan on using the Pine as a learning tool. I found this teardown that shows the components of the S4...
https://www.ifixit.com/Teardown/Samsung+...down/13947
Hi
u need to check if that screen of the S4 is MIPI 4 Lines compatible and whats the pinOut of the connector
the driver u can pull it from s4 kernel source
but make sure that the display pinout matches with the PINE
By. Zoidiano0!
Installed:
LAMP: Linux , Apache2.4 , Mariadb, phpMyadmin, PHP5
Java 8 arm by oracle
Netbeans 8.1
chromium (uses way toooo much Ram)
Pine64 Head Unit Project.!
Unfortunately the screen is pretty much the only part of the phone that's broken :\
