Bluetooth audio stalling (maybe the whole phone)
I have a farm with Wifi in various spots. It is the same ESSID everywhere but there are areas with no coverage. There is no cellular coverage.
The following is repeatable behavior.
I often listen to podcasts via bluetooth using the 'podcasts' app and playing from files loaded locally on the phone.
If I am listening to a program as I drive and I transition from the Wifi coverage area to a non coverage area the blue tooth stutters (it cuts in and out). It seems like the Wifi losing its connection interferes with the ongoing bluetooth audio.
The audio is not stalling but is lost.
Eventually the bluetooth audio recovers and when I enter an area with Wifi a similar stuttering occurs.
The behavior is very repeatable and happens every time I make the drive while listening to a podcast.
Since the behavior is repeatable is there something I might look to to help identify what is going wrong?
I've previously experienced bluetooth dropouts on the pinephone when a background process has briefly hogged the CPU. You could try looking with something like htop while repeating the behaviour to see if the transition triggers a task that may be causing issues. Someone more skilled can probably point to a method to get it logged automatically. Another possibility is that there's something not configured or implemented correctly with the wifi/bluetooth chip driver since they share the same chip and antenna - they're supposed to have mechanisms to avoid interfering with each other, but that may not work under all circumstances. I'm not sure how you'd look into that though.
  Bluetooth audio revisited 3x5co 1 1,087 01-10-2023, 05:51 PM
  No audio on calls after updating today Zebulon Walton 10 4,351 12-12-2022, 09:55 PM
Last Post: BaronAlbatross
  phone does not ring (when sleeping) jsch 2 1,500 10-07-2022, 08:08 AM
Last Post: alaraajavamma
  Ringtones and Audio Modes biketool 0 768 09-05-2022, 10:42 AM
  Giving certain audio apps priority on the lock screen and pulldown 3x5co 0 864 07-17-2022, 10:34 AM
Last Post: 3x5co
  Any fix for bluetooth crash when entering pairing password? kk22 0 860 06-18-2022, 07:51 PM
Last Post: kk22
  Blueman GUI Bluetooth Network Access Point - fixing Bridging biketool 12 8,141 05-26-2022, 05:56 AM
  MATE on pine phone user641 6 3,772 05-05-2022, 09:44 AM
  Scripting Bluetooth Hotspot for Mobian biketool 1 1,528 03-20-2022, 03:03 PM
  Bluetooth audio support? Zebulon Walton 5 3,702 02-28-2022, 08:59 AM
