SIM adapter suggestion
Lightbulb
I have seen quite a lot of people getting frustrated with their SIM adapters and i would like to propose a solution / future design upgrade:
I had the same exact issue with the SIM adapter, i solved it by cutting the end of the adapter so I could insert the SIM card without removing the adapter. I tried removing the adapter with the SIM inserted and it did not break any parts so far.
I would suggest either users cutting off the end of the adapter so it's possible to insert SIM card into the device without attempting to ruin the pins or Pine team to make and provide in the box a modified SIM adapter of course if there is a possibility.
  Wifi no scan results - Bluetooth adapter not available emsyr 1 1,405 08-29-2022, 02:46 PM
Last Post: emsyr
  Pinephone could have better cooling (suggestion) computerc 3 2,215 07-22-2022, 11:39 AM
Last Post: computerc
  Seeing no WWAN adapter or No SIM jcun4128 2 2,534 03-04-2022, 02:23 AM
Last Post: jcun4128
  SIM or SIM Adapter stuck, potential fix. thefunnyman 0 1,042 12-07-2021, 08:16 AM
Last Post: thefunnyman
  Suggestion: better performing pinephone coolguy129 33 30,987 10-29-2021, 06:38 AM
Last Post: TRS-80
  Will 5GHz USB wifi adapter work? Zebulon Walton 1 2,677 12-01-2020, 06:17 PM
Last Post: nas
Lightbulb Future device suggestion: smaller form factor MotoFufu9k 6 7,732 06-09-2020, 07:55 PM
Last Post: 1ZachM
  Nano sim to micro sim adapter not working Qiangong2 5 7,145 06-09-2020, 02:22 PM
Last Post: bcnaz
