Screen blinking
Hi, I have rock64 v3.0 and screen is blinking quite much. With "blinking" I mean black rectangles that appear and disappear on screen when I move or resize window, also screen is "shaking" when it happens. Don't know how to describe it accurately with text, I can record a video if someone needs it. I tried armbian focal, it had lima driver. Also I tried slackware with mali driver, the blinking was gone when I decreased resolution to 1600x900 (resolution of my monitor is 1920x1080). I wanted to do this on armbian but other resolutions were not available, xrandr printed only 1920x1080.
Does anyone know how to fix it?
Hi, I know this is quite an old topic but I've fixed this issue. The problem is that the memory controller didn't give preferential treatment to the video output controller, so if there was a lot of memory activity, it'd miss the required timings.
The fix is to set the quality of service registers in u-boot, I've written a patch that does this and submitted it to u-boot upstream, so that it will hopefully be included in the future.
I have yet to write a patch to the kernel that saves/restores these registers on power domain changes, but this is good enough to fix the issue in most cases now.
As for when this will trickle down to distributions I don't know. If there's interest, I'll write some instructions on how to compile u-boot for rk3328 and put them on the wiki; that way people can use the patch before distributions have it.
Occasional Linux Kernel Contributor, Avid Wiki Updater, Ask Me About Quartz64
Open Hardware Quartz64 Model A TOSLink Adapter
Pi-bus GPIO Extender For ROCKPro64 And Quartz64 Model A
Plebian GNU/Linux
(07-23-2022, 05:50 AM)CounterPillow Wrote: Hi, I know this is quite an old topic but I've fixed this issue.
Thanks!!
Quote:I've written a patch that does this
I'll try it as soon as I have free time Smile
Quote:If there's interest, I'll write some instructions on how to compile u-boot for rk3328 and put them on the wiki; that way people can use the patch before distributions have it.
I used this guide https://stikonas.eu/wordpress/2019/09/15...rockpro64/ with making some changes for rock64 and it worked. (I did it after making previous post, not related to this topic). It's enough to do it again with your patch, right?
  Rock64 Rev3 doesn't boot and leds blinking fast dishins 6 14,171 06-30-2022, 06:28 PM
Last Post: rookie_267
  Armbian 5.4.43: Network is unreachable; Red LED blinking; RNG failure? aves 1 5,604 07-27-2020, 02:04 PM
Last Post: aves
  Screen lock fail Bionic-lxde-rock64-0.7.8-1061-arm64 electrique 0 3,713 12-28-2018, 11:00 PM
Last Post: electrique
  Screen flickering when playing multiple videos with rkximagesink matwey 2 6,852 05-15-2018, 02:09 AM
Last Post: matwey
  x11 vnc black screen soichiro 12 28,657 01-27-2018, 08:20 PM
Last Post: soichiro
