Unable to configure mmc2 on pinecube in 4 bit SDIO mode
Attempting to enable the third mmc port in 4 bit mode with little progress.  I enabled it via dts & disabled the spi0 port which shares the same pins. The system comes up, sees the peripheral.. but thats about as far as I can get.
I pulled off the RTK8189ES module and soldered my peripheral in its place and it works fine.
Some details...
dmesg log w/errors
[    1.377523] sunxi-mmc 1c11000.mmc: initialized, max. request size: 16384 KB
[    1.404182] mmc2: new high speed SDIO card at address 0001
[  17.998911] sunxi-mmc 1c11000.mmc: data error, sending stop command
[  18.005356] my_driver mmc2:0001:2: sdio readl failed -110
changes to sun8i-v3s.dtsi
mmc2: mmc@1c11000 {
  compatible = "allwinner,sun7i-a20-mmc";
  reg = <0x01c11000 0x1000>;
  clocks = <&ccu CLK_BUS_MMC2>,
  <&ccu CLK_MMC2>,
  <&ccu CLK_MMC2_OUTPUT>,
  <&ccu CLK_MMC2_SAMPLE>;
  clock-names = "ahb",
      "mmc",
      "output",
      "sample";
  resets = <&ccu RST_BUS_MMC2>;
  reset-names = "ahb";
  interrupts = <GIC_SPI 62 IRQ_TYPE_LEVEL_HIGH>;
  pinctrl-names = "default";
  pinctrl-0 = <&mmc2_pins>;
  status = "disabled";
  #address-cells = <1>;
  #size-cells = <0>;
mmc2_pins: mmc2-pins {
 pins = "PC0", "PC1", "PC3", "PC4",
        "PC5", "PC6";
  function = "mmc2";
  drive-strength = <30>;
  bias-pull-up;
changes to sun8i-s3-pinecube.dts
&mmc2 {
  vmmc-supply = <&reg_dcdc3>;
  bus-width = <4>;
  non-removable;
  status = "okay";
&spi0 {
   status = "okay";
   flash@0 {
  #size-cells = <1>;
  compatible = "winbond,w25q128", "jedec,spi-nor";
  reg = <0>;
  spi-max-frequency = <40000000>;
Answering my own question here...
mmc2-pins has to include ALL mmc pins even if only using 4 bit mode.
  Do you sell a ready-made housing for the PineCube camera? Mikoduso 1 7,957 10-05-2022, 01:44 PM
Last Post: Mikoduso
Video Examples of surveillance video recordings via PineCube? Mikoduso 0 3,645 03-26-2022, 12:21 PM
Last Post: Mikoduso
  What is the operating temperature of the PineCube? Mikoduso 0 3,418 03-26-2022, 12:13 PM
Last Post: Mikoduso
  setting a fixed Mac address on a PineCube ajellisuk 3 8,097 11-29-2021, 07:36 PM
Last Post: lgtrombetta
  Can PineCube stream 720p60fps? epoliqui 1 5,914 08-30-2021, 10:02 AM
Last Post: barray
  Existing CAD model for PineCube? symbol_reform 13 27,855 04-19-2021, 06:57 AM
Last Post: BigGremlin777
