After first start: Update not possible
Question
Hi
I got the PinePhone yesterday and started the setup. Until here, all is fine.
I want start the update over Terminal, the download is finished, but the installer will not update.
My steps
- get updates files: sudo pacman -Suyw
- start installer: sudo pacman -Suy
The first error in the first update process is direct after keyring checking:
error: failed to commit transaction (conflicting files)
manjaro-system: /etc/sudoers.d/10-installer exists in filesystem
manjaro-system: /usr/bin/resize-fs exist in filesystem
manjaro-system: /usr/share/libalpm/hooks/networkmanager-connectivity.hook exist in filesystem
Errors occured, no packages were upgraded.
::Starting full system upgrade...
:: Replace python-dbus with etxra/dbus-python? [Y/n]
Error occurred, no packages were upgraded.
Probably the version installed in factory is quite old and therefore there could be changes is manjaro packaging setup.
You can solve it either by: flash latest pinephone plasma mobile image or move these 3 conflicting files to temporary location and try again...
I installed fresh
Question New user/phone here - initial update issues sexywheat 2 1,744 06-29-2022, 04:27 PM
Last Post: sexywheat
  MMS Status Update - Lots of progress! kop316 2 5,358 12-12-2020, 05:47 PM
Last Post: kop316
