Multiple issues with new phone
Hello!
So I got my phone yesterday and the excitement was well y'all know! Anyhow I followed the simple instructions the phone came with to get it started up. All good no problem. Once I got the basic start up completed I pretty much left the phone on the charger for the night (12+ hours) and it indicated it was charging but it never got past 86% charge.
Next the brightness won't stay where I set it and slides up and down until finally it just won't  stay illuminated (screen is black). But if I plug the phone in, it works. So on battery power... its whacky. I got an AT&T SIM installed (seems to work, I was able to call and receive calls) but for the life of myself and the fellow helping, I could not find a way to enter the APN. So I don't have access to the data plan...
Network connection, been trying to find a network connection protocol... not so much luck with that either.
I did manage to get a 600+MB update installed, I had hoped it would have resolved the screen issue. But now it seems to do it even when plugged in!? So I get this is BETA but I am kind of not sure where to go from here. Tips? Advice?
(04-24-2021, 03:26 PM)GlockG20 Wrote: Hello!
To help protect the health of the battery there is a charging cutoff in the kernel atm. Not sure personally how you'd change it, but it's not in the UI as an option. Brightness changing especially after suspend is a known issue and hopefully will get solved. As for it going black, I assume you mean it's turning off after a few seconds? That's the suspend and screen timer turning off the screen and eventually putting the phone to sleep to save battery. Unfortunately that too has a known issue at the moment which means that the screen settings panel in the settings does not actually work, so you can't stop it from turning the screen black or going into suspend unless you tap on the screen every few seconds. Mobile data is also an known issue, and is actually being actively worked on, so hopefully soon there will be a solution for that. These issues are exactly why this device is considered in beta still, as while the hardware has matured, the software still needs lots of work and is not really user friendly for now.
Okay, I didn't expect to be able to replace my droid yet, but I thought the basics were covered. All good! I read somewhere that there are different flavors for the phone that allow a bit more control. I managed on one occasion to stumble on the software repository and applications installed function... but have not been able to find it again.
Currently on my mini-PC and laptops I run Linux Mint so I am not familiar with Plasma or Manjaro (which is rather ironic as when I started cutting my teeth on Linux it was with Mandrake!)
The big thing for me is to be able to get into the phones applications and settings and play with them, see if I can find solutions or work arounds. And in this back to my reading... there are different "OS's" that can be installed onto the phone. Would you recommend I pursue that venue? Or keep bashing at the Manjaro install?
And thank you for the reply! Much appreciated!
My personal preference is plasma mobile, simply because it runs smoothly thanks to using QT's GPU acceleration, looks really nice, and uses the same technology stack as plasma desktop basically (so it will share features with plasma desktop too). However Phosh is definitely a little less buggy than Plasma Mobile and is more usable at the moment, so if you want something mostly functional for now I'd play with that. So with that said my recommendation would be for now to just keep Manjaro Plasma on the eMMC as it came from the factory, and install Arch Linux arm with Phosh or postmarketOS with Phosh onto a SD card to play around with, however it's up to you what you want to try out and play with.
(04-24-2021, 03:26 PM)GlockG20 Wrote: Next the brightness won't stay where I set it and slides up and down until finally it just won't  stay illuminated (screen is black). But if I plug the phone in, it works.
It seems that the Settings -> Screen setup application is still not fixed - see the following thread:
https://forum.pine64.org/showthread.php?tid=13481
What distro works I have had my Pinephone more than a year and noting works I think they shipped me a defective phone since I can not make phone calls, text, email, play mp3 or video files, take pictures or videos .
None of the basic functionality works I would like to test and verify they do work.
I can not understand how they can build and test ship and nothing functions.
Thanks.
Thanks.
You really need to test your hardware using the factory test build in the wiki under operating systems
Thanks.
Have you updated your distribution? Have you tried other distributions? What carrier do you have?
  Default password for KDE plasma pine phone Toni 0 8,569 09-14-2025, 06:35 PM
Last Post: Toni
  BalenaEtcher issues... gtamichael 6 5,855 03-26-2025, 09:22 AM
Last Post: gtamichael
  Modem crashes worsening from daily to multiple times a day + sms delaysFor people car bacydentir85 2 4,224 02-03-2025, 01:34 PM
  My new phone stopped working. gunnygee 3 5,002 12-12-2024, 01:21 PM
  Pine Phone in Australaa and Telstra tracyanne 2 3,482 12-06-2024, 02:42 AM
Last Post: tracyanne
  Can't complete update of manjaro: wwan0 stays disabled; no phone/text gilford 3 4,637 12-05-2024, 06:42 AM
Last Post: gilford
  2G, 3G still is in phone. Piotr Bujakowski 5 7,089 09-19-2024, 03:49 AM
Last Post: jennybaso
  Looking for the "non-phone" OS wakyct 7 9,537 03-14-2024, 03:51 AM
Last Post: MTXP
  Writing apps/programs for pine phone katesfb 7 13,317 03-11-2024, 10:42 PM
Last Post: Emelia525
  How To Access the Pine Phone Auxillary microSD Without Removing Card pinephoneuser22 2 4,922 01-09-2024, 07:02 PM
Last Post: britelite
