Pine Phone Desktop Mode or "Standard" Gnome Desktop on PinePhone?
I'd like to install a standard mobian/debian distribution to use my pinephone as a very small desktop replacement with a fullsize BT Keyboard + Mouse but  I got many of small Problems which are real showstoppers right now....
- The Display is still vertical and I see no way how to configure it to be 'normal' horizontally orientated, even after modifying the xorg.conf (or wayland)
- despite the fact I uninstalled (purged) POSH  it still boots automatically into the "old" system - gdm3 is installed but is ignored anyway...
- I don't get any framebuffer bootscreen with the kernel messages as all other devices do... don't know why my parameters while booting are absolutely ignored, it seems?
Maybe it's the wrong way to take a mobian an uninstall all "unneccessary" stuff from it, maybe there is a better way to start off a 'minimal debian' image on the phone?
Thanks a lot!
Cheers
4920441
If you follow the instructions in https://wiki.mobian-project.org/doku.php...ble%20gdm3 you should get get your gdm3 environment on reboot. That will probably sort out the orientation issue too. No idea on the other q's, but I'm sure someone will have...
Cheers
(04-06-2021, 05:34 AM)4920441 Wrote: - despite the fact I uninstalled (purged) POSH  it still boots automatically into the "old" system - gdm3 is installed but is ignored anyway...
If you're sure gdm3 is installed then try:
sudo systemctl disable phosh
Some extra/optional steps here and here.
so far so good.
But I still don't get a text/framebuffer bootscreen and permanent orientation is not possible either, despite I tried a lot with the options which are commented with "for pine Tab only"...
Login works and now I get my gnome desktop running in the 'correct' Aspect ratio, that is working fine so far.
(But... I think its too small anyway to use it as a desktop replacement.... will try out a HDMI Out Adapter, but then the whole concept is broken anyway:-)
Cheers
4920441
On Fedora using gdm, gnome 40 is running really good with screen rotatation, kernel 5.12, or back to phosh if needed...
  Using Signal on PinePhone in mid-2023? dante404 47 14,122 05-03-2024, 02:19 AM
Last Post: dragonhospital
  Slarm64 on PinePhone [Unofficial Slackware ARM - 64 bit] acid andy 38 25,620 04-23-2024, 10:29 AM
Last Post: donchurch
  PinePhone app development WhiteHexagon 15 4,212 04-23-2024, 05:19 AM
Last Post: Jonnyc
Wink PINEPHONE not booting Touchwood 2 550 02-23-2024, 07:27 AM
Last Post: Touchwood
  Slack on PinePhone Adam Seline 5 5,518 12-20-2023, 07:20 AM
Last Post: nickolas
  Struggle to install LibreOffice on the PinePhone Peter Gamma 48 24,921 11-24-2023, 07:02 AM
Last Post: Peter Gamma
  Which word processor to choose for the Pinephone? Peter Gamma 8 2,166 11-23-2023, 01:06 AM
  openSUSE for Pinephone Alefnode 75 103,232 11-17-2023, 08:37 AM
Last Post: Uturn
  Genode- Sculpt OS for the PinePhone (non Linux) Surehand53 1 1,061 11-04-2023, 07:23 PM
  is there an progam to forward calls and texts to my desktop dallytaur 2 968 11-01-2023, 04:55 AM
Last Post: Samurai_Crow
