Battery gauge issue (mainline kernel)
I'm trying to use Debian on a Pinebook Pro using the official bullseye installer.  (I'm aware of the unofficial installer!)
Mostly, it works quite well! For the record:
 * the installer created an additional partition (dummy partition to protect the bootloader, maybe?) that confused u-boot; deleting the partition fixed the problem (I plan to reproduce the unofficial installer's nice partition scheme later);
 * the screen remains blank (I installed using a serial cable) because the kernel gets confused by the video + usb-c port; this can be worked around by removing
&cdn_dp {
    status = "okay";
from the .dts (in the kernel sources), rebuilding the .dtb, and inserting the .dtb in /etc/flash-kernel/dtbs. (Information from https://www.reddit.com/r/PINE64official/...ne_kernel/ );
 * the battery gauge is not working (this is the reason for this post);
 * there is something wrong with the audio output, which I have not investigated (the uart/audio switch is set to uart, for serial output, it would make sense to try setting it to audio first).
From dmesg, I see a few messages related to the battery gauge:
[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
[    0.000000] Linux version 5.10.0-3-arm64 (debian-kernel@lists.debian.org) (gcc-10 (Debian 10.2.1-6) 10.2.1 20210110, GNU ld (GNU Binutils for Debian) 2.35.1) #1 SMP Debian 5.10.13-1 (2021-02-06)
[    0.000000] Machine model: Pine64 Pinebook Pro
(snip)
[    7.150366] power_supply cw2015-battery: Not all required supplies found, defer probe
[    7.150384] cw2015 4-0062: Failed to register power supply
(snip)
(The two lines about cw2015 are repeated a few times, later.)
My understanding is that cw2015 support has been mainlined and should work with a mainline kernel.  I don't really understand what the "Not all required supplies found" message is about, but dmesg does not seem to have errors relating to the DC input not the USB-C input.  This is the only occurrence of "power supply" in these messages.
The same errors appear with the original .dtb file, so this is not a side effect of the above change.
Do you know what is causing the cw2015 driver to fail?  Any suggestion for a fix or workaround would be highly appreciated!
Best regards,
Lionel
Answering my own post: this was caused by missing drivers in the Debian kernel: enabling CONFIG_TYPEC_FUSB302 (requires CONFIG_TYPEC and CONFIG_TYPEC_TCPM) and CONFIG_SND_SOC_ES8316 makes the type-c port, battery gauge and audio work.
This is currently fixed in Debian sid (from version 5.10.38-1 of linux-image-amd64).
One remaining oddness is that the usb-c port does not always work in all orientations: reversing the usb connector can make a usb device work.  Does anyone understand why this is happening?
(05-22-2021, 03:58 AM)lfourquaux Wrote: Answering my own post: this was caused by missing drivers in the Debian kernel: enabling CONFIG_TYPEC_FUSB302 (requires CONFIG_TYPEC and CONFIG_TYPEC_TCPM) and CONFIG_SND_SOC_ES8316 makes the type-c port, battery gauge and audio work.
I believe you meant `linux-image-arm64`. What's your experience with it so far? I've seen some instability around WiFi - device likes to disappear out of the blue, haven't noticed any pattern yet. With xmixahx's 5.8.x I had it disappear only occasionally after deep sleep, but with 5.10.0-7 of Debian it can sometimes disappear in the middle of my typing up a message in IM.
(05-22-2021, 03:58 AM)lfourquaux Wrote: One remaining oddness is that the usb-c port does not always work in all orientations: reversing the usb connector can make a usb device work.  Does anyone understand why this is happening?
AFAIK Type-C is not perfectly reversible, and that was brought up before. Somebody on these forums even referred to the USB-C spec not guaranteeing 100% reversible connection. Which seems to me to defeat the purpose, but oh well. I haven't spent enough time reading the spec to tell whether it is an issue with the hardware spec or if it is a software (driver) issue.
This message was created with 100% recycled electrons
(05-22-2021, 09:53 AM)moonwalkers Wrote: I believe you meant `linux-image-arm64`.
Indeed!
(05-22-2021, 09:53 AM)moonwalkers Wrote: What's your experience with it so far? I've seen some instability around WiFi - device likes to disappear out of the blue, haven't noticed any pattern yet. With xmixahx's 5.8.x I had it disappear only occasionally after deep sleep, but with 5.10.0-7 of Debian it can sometimes disappear in the middle of my typing up a message in IM.
Very good experience overall.  Regarding WiFi, it has been very stable for me, though a bit slow (the Pinebook Pro has 1 stream only; even my phone has 2).
I have read on the Pine64 wiki that 2.4GHz WiFi may be unstable.  I have mostly, but not exclusively, used 5GHz networks.  (FWIW, I used iwd to configure the WiFi adapter.)
The remaining pain point is audio input.  The builtin microphone seems very poor, but I also had poor sound quality with a usb mic that worked fine on another computer.  I'm still experimenting and it may be only a software misconfiguration.
(05-22-2021, 09:53 AM)moonwalkers Wrote: AFAIK Type-C is not perfectly reversible, and that was brought up before. Somebody on these forums even referred to the USB-C spec not guaranteeing 100% reversible connection. Which seems to me to defeat the purpose, but oh well. I haven't spent enough time reading the spec to tell whether it is an issue with the hardware spec or if it is a software (driver) issue.
Thanks for these informations!
What software are you using to record audio?
I use a RØDE NT-USB Mini with SimpleScreenRecorder and I it works like a charm.
I haven't tried to use it with video conferencing, as you need to keep the RØDE very close to your mouth.
This is an example of how it sounds.
https://youtu.be/XN7ZEmgVBzA
  pbp with manjaro arm seems to not find any hardware[no wifi, blutooth or battery] frank_philip 4 4,800 03-15-2025, 01:47 AM
Last Post: frank_philip
  Improved battery life with TLP daemon Surehand53 0 2,769 12-30-2024, 07:46 AM
Last Post: Surehand53
  How to mainline kernel on daniel thompson's debian installer? hellojack 14 20,002 09-07-2023, 09:38 PM
  Manjaro - HIbernate - brcmfmac clk issue pompeyPinePro 1 2,716 08-18-2023, 02:06 AM
Last Post: juliamenendez
  Issue with booting Manjaro from encrypted NVMe drive on pbp Cs137 1 2,919 08-18-2023, 01:58 AM
  kernel module that supports usb-c hdmi alexandre 16 27,177 05-14-2023, 09:58 PM
Last Post: rathofkhan3
  Manjaro update: nerd-font-terminus dependency issue Vinay 3 4,065 05-10-2023, 04:51 AM
Last Post: Vinay
Question Debian (Vanilla) no output on display after Kernel update (6.0.8-1) as365n4 1 4,090 12-09-2022, 12:43 PM
Last Post: as365n4
  Manjaro update: wxgtk dependency issue Vinay 5 6,902 09-09-2022, 12:03 PM
Last Post: Vinay
  bootloader menu to pick a kernel - what is the current situation in in early 2022? maxtothemax 4 7,584 02-05-2022, 03:04 PM
Last Post: maxtothemax
