Floating Point Math performance
  while making some benchmark with the rockPro64 using PassMark tool, I noticed that the "integer math" is 4+ times higher than the  "Floating Point Math" whereas in a lot of results for other processors (AMD or Intel) it is usually less than 2. Do you know where the gap comes from ? math coprocessors ?
I do not know if it make sens, but is it possible to use the mali GPU to performs math ops (I do not use any Graphical interface) ?
LMM.
  RPI4 Vs Rockpro64 Performance help? Mangled 0 3,155 05-25-2021, 03:38 PM
Last Post: Mangled
  Performance and Power Demand RockPro64 fotastisch 7 18,798 02-05-2021, 07:45 PM
Last Post: foresto
  Power consumption math Mentaluproar 0 2,939 11-21-2019, 11:02 AM
Last Post: Mentaluproar
  Performance issue/question bobdaroze 8 18,194 11-11-2018, 10:41 PM
Last Post: tuxd3v
  Some performance comparisions pfeerick 3 9,094 06-16-2018, 03:23 AM
Last Post: pfeerick
