Another PBP with a case crack
https://imgur.com/a/kqq1hpP
I noticed this when it was about a year old, I see other people are getting cracks too.  I've had it open a few times, all the screws are back in it.  Dropped it a couple times but it just slid off my lap onto carpet.  Opening the lid causes the crack to open up.
[Image: kqq1hpP]
(03-05-2021, 11:52 AM)ab1jx Wrote: https://imgur.com/a/kqq1hpP
[Image: kqq1hpP]
"Dropping a few time "  no really count as problem with PBP design or construction Rolleyes  I sure you can order new case ..
Yes, but I have to do it very year?  Parts availability seems to vary, one time I looked i found exactly what I needed, now I don't.  I don't need the keyboard or touchpad, it's just a plastic piece.  Some parts at https://pine64.com/product-category/lapt...46c16e2e66 or https://pine64.com/product/pinebook-pro-...46c16e2e66
This is maybe my 10th laptop in 20+ years.  This is what I'd call a hinge problem because too much resistance in the hinge causes the case to crack here.  I have an HP downstairs that I gave up on opening and closing but it's still running fine. I gave away an Acer that I cobbed together with aluminum and JB Weld epoxy.  I've bought several "fixer upper Dells", the last for $35.  Search on eBay for "no hard drive", you're looking for machines that came off lease.  Download the service manual PDF and search for the part numbers, you can find parts on eBay too, somebody bought out the factory's leftover stock.
I don't remember what's just inside this piece, I'd try to bridge it with metal on the outside held on with machine screws and glue.  But I didn't expect to need to.
I did a quick search and dug up these 2 posts about similar cracks.
https://forum.pine64.org/showthread.php?...ight=crack
I almost wish I hadn't invested in putting a 1 TB nvme drive in it, but I've since bought a 2 TB to use in a USB adapter so I know I can take this back out.
  Silicone case for PineBuds Pro Liz_34 0 696 01-12-2023, 09:30 AM
Last Post: Liz_34
  Pine64 quality of the hardware support : the PinePhone case Gribouille 7 4,875 10-07-2021, 11:26 AM
Last Post: ypd
  Rackmount cluster case as a Pine Store product? dfr 3 3,424 09-30-2021, 04:52 PM
Last Post: poVoq
  Counter for Soft TPU case (Reduce Digital Gap) PakoSt 10 10,917 09-09-2020, 07:09 AM
Last Post: PakoSt
