UI is a bit laggy
I make some tests, glxgears works with 60 fps so it's KWin/KDE or Qt specific issue of a bit laggy UI, glxinfo shows correct info, it has correct kernel driver, any ideas?Does anyone knows others DE's Gnome how is compared to Plasma? Or other kernels/drivers?
I have update on that run in konsle
kcmshell5 kwincompositing
select Opengl2 and prefer smooth animations. Actually Opengl3 should be unavailable in Opengles devices i think.
