X11 Forwarding
Hello guys i am working on a little project: https://www.reddit.com/r/pinephone/comme...&context=3
Now i want to connect from my pinephone via X11 Forwarding to my vm(ubuntu) on a hypver-v.
pinephone has Manjaro posh on it.
Which is using wayland.
I always get following errors on the pinephone:
- the xauth error
- And that it can not find any display
Nearly same as here: https://forum.pine64.org/showthread.php?tid=11755
Does anyone know what i can do? I don't realy get the other thread and i think they are trying do connect to the pinephone not from the pinephone Big Grin
The X11 Forwarding over putty and stuff on other clients works great Big Grin
Edit:
As in the other thread said this site is very good: https://www.dbts-analytics.com/notesxfwdgb.html
On the Pinephone:
1. Xephyr -br -ac -noreset -screen 1150x850 :8
To connect use:
2. DISPLAY=:8 ssh -X trinidad@10.42.0.73 -p 54321 gnome-boxes 2>/dev/null
But it still does not work Sad
Still both errors Sad
So you know, you can't do X11 forwarding with Wayland. Look into waypipe:
https://www.mankier.com/1/waypipe
It is even on Windows (Window Manager?) possible to open a x11 sessions over putty and xming(which acts as a x11 server). That has to be possible on wayland as well.
waypipe seems to be the way to go thanks Smile will take a look at that Smile
Edit: as i normaly work with x2goclient to get easy acces to sessions etc. i found a way for x2go to work Smile
https://wiki.archlinux.org/index.php/X2Go
Quote:Follow the instructions in Desktop entries#Modify environment variables and change the lines starting with
Exec=x2goclient
to
Exec=env QT_QPA_PLATFORM=xcb x2goclient
  Volunteer firefighter needs help forwarding alam message Veraendert 8 3,502 08-23-2022, 02:19 PM
Last Post: bosi564
