02-15-2021, 12:54 AM
I don't really like the vibration motor, and I figure it would save more battery if it was disabled. How do I do it?
Disable vibrations
03-13-2021, 02:45 PM
I would also like to know how to disable vibrations, maybe someone could share some insight.
In general, the system settings menu could use some attention. Ive used mobian for 6 months and I still dont know how to change the ringetone without breaking anything
03-13-2021, 04:18 PM
03-13-2021, 05:03 PM
(02-15-2021, 12:54 AM)3x5co Wrote: I don't really like the vibration motor, and I figure it would save more battery if it was disabled. How do I do it? One approach would be to cut the vibration motor's wires or pry it apart to break its internal wiring. I did that accidentally when replacing a cracked screen.
03-15-2021, 03:37 PM
(03-13-2021, 05:03 PM)Zebulon Walton Wrote: One approach would be to cut the vibration motor's wires or pry it apart to break its internal wiring. I did that accidentally when replacing a cracked screen. Sounds like fun! Just need to find out how it looks like so I dont go cutting off the wrong thing.. do you know of some schematics or relevant pictures?
Hey guys,
before you rip your phones apart to cut some wires... What do you think about "cutting wires" in software? Have a look here: https://gitlab.com/mobian1/devices/sunxi...phone.dtsi Especially this entry gives the needed information: Code: vibrator { So if you are familiar with kernel compilation you could disable this entry by comment out the vibrator part in the DTS and generate a new dtb file. There should also be some system service handling this, but i'm still searching... EDIT: O.k. dbus.service is starting /usr/libexec/feedbackd which handles the vibrator afterwards. So you could start tweaking the theme for pinephone at: /usr/share/feedbackd/themes. But maybe this isn't nasty enough The daemon feedbackd has a rules definition in /lib/udev/rules.d/90-feedbackd.rules In this file there's a definition for the vibrator: Code: SUBSYSTEM=="input", KERNEL=="event*", ENV{ID_INPUT}=="1", ENV{ID_PATH}=="platform-vibrator", TAG+="uaccess", ENV{FEEDBACKD_TYPE}="vibra" Maybe it's enough to uncomment this line with "#". Just a thought... i did not try that. AFAIK this stuff is all handled by the kernel event system, look here as a reference (pinephone console output, the last entry): Code: mobian@mobian:/dev/input/by-path$ ls -l Maybe this helps in any way. Cheers, scholbert
01-22-2022, 01:41 PM
(03-16-2021, 04:43 AM)scholbert Wrote: The daemon feedbackd has a rules definition in /lib/udev/rules.d/90-feedbackd.rules I tried commenting that line out. It works to shut down all vibration notifications. Which is nice. Not so nice: it also seems to shut down ALL notifications from the phone. No ringing for calls, no tones for texts, nothing. I'm not sure why some incredibly ordinary functionality simply does not seem to appear on the pinephone. Being able to assign ringtones to individuals and groups, being able to silence ringtones, being able to turn vibration on and off. It's been two years now. *Please* do it! I'd be really really grateful for a solution to this. I don't mind editing config files. But on the larger issue of the phone's usability for the general customer, this really needs to be easy to do in the phone app (or Settings) itself. It's not simple enough for me to have ever found it
OS: Mobian Bookworm, Phosh. Pinephone Braveheart from 2020-02-11
05-14-2022, 12:17 PM
I followed the description in the feedbackd README and
Finally I set the feedback profile to 'full' (it was 'silent' before because I didn't like the vibrations): Code: gsettings set org.sigxcpu.feedbackd profile full Finally my PinePhone has sound notifications without vibrations
06-11-2022, 09:59 AM
Easier way than doing anything with the DE would just to echo "blacklist gpio_vibra" (lsmod revealed this to be the relevant module) into /etc/modprobe.d/vibrate so it won't start the driver for it on boot.
how to disable ipv6 at kernel level with towboot? | vusra | 2 | 911 |
07-09-2023, 01:25 AM Last Post: vusra |
No boot after upgrade: vibration, red LED, then 2 vibrations and yellow LED | 3x5co | 1 | 997 |
01-04-2023, 06:46 PM Last Post: 3x5co |
Disable headphone controls | 3x5co | 0 | 659 |
09-10-2022, 07:11 AM Last Post: 3x5co |
Disable *automatic* on-screen keyboard | iwakura_lain | 0 | 940 |
06-11-2022, 09:49 AM Last Post: iwakura_lain |
Disable on screen keyboard permanently. | grump_fiddle_reinstall | 12 | 9,370 |
06-11-2022, 08:11 AM Last Post: SwordfishII |
Possible to disable display of SMS text messages? | Zebulon Walton | 2 | 3,232 |
12-08-2020, 05:32 PM Last Post: Zebulon Walton |
Speed up Mobian performance: disable animations | 3x5co | 1 | 3,334 |
11-25-2020, 10:16 AM Last Post: elagost |
