502 Bad Gateway
Hello Pine64-Admins,
starting 2021 I have problems trying to access threads in the forum. Either an empty page is displayed or I get an "502 Bad Gateway - nginx/1.14.2" error. Only a few threads work fine.
examples:
https://forum.pine64.org/showthread.php?tid=12864 => 502 Bad Gateway
https://forum.pine64.org/showthread.php?tid=9683 => empty page
https://forum.pine64.org/announcements.php?aid=25 => works fine
When reloading these pages including cache reset their status does not change.
I can reproduce the error with Firefox 84 and 85 on Windows 10 Pro 64 Bit v20H2 with the latest patches while Microsoft Edge works just fine.
In Firefox the problem only occurs when accessing the forum as a guest. After I logged in the problem is gone.
This might be a problem with your nginx configuration or a bug in Firefox or some problem with the forum software and the cookies it uses.
Hope this helps
Michael
I don't normally use firefox for browsing the forum, but I tested the links in firefox and they worked fine, so caching is all I can come up with. Did you wipe cookies and so on?
Likewise, these links work perfectly fine for me.
Maybe try again now, could be that either side was glitching.
母語は日本語ですが、英語も喋れます(ry
  Cannot pay with credit card: VISA: "card was declined.". MasterCard: "Bad Gateway". dreieck 4 2,681 04-15-2023, 04:21 PM
Last Post: pinkkat
