[Request] Manjaro 20
Information
Hello, i am new here.
I used my Rock64 (4Gb Ram) with Manjaro 19.04,
does anyone have a ready image for Manjaro 20?
Since Manjaro 19.04 is not longer supported...
Thanks for Help.
Hello Rikku2000, they still support the Rock64, just don't build images, you have to burn it with manjaro-arm-installer on a Linux PC.
I haven't tested Manjaro ARM in a long time.
Bye
Thanks, but i mean is there someone how had an raw image can share to me.
so i just use etcher to Burn on my SDCard.
Thanks for Help.
Sorry for not being helpful but that approach means that someone must use the Manjaro ARM installer (MAI) in the tiniest SD card possible (probably slower too) so he can make a small image. Then upload it.
The MAI let you choose before burning user, pass, locale and more, so that image would already be customized.
Sorry but my upload speeds are potato speeds, (~90 KBps). And big files cripple my overall network.
Thumbs Up Manjaro for Rock64 Luke 8 14,532 05-18-2020, 02:58 AM
Last Post: camosoul
  Arch-Manjaro attempting gles2 setup tomarm 2 3,450 12-28-2019, 01:33 AM
Last Post: tomarm
  [feature request] please enable memtest in the kernel prof7bit 0 1,624 03-13-2018, 11:46 AM
Last Post: prof7bit
