64bit Docker
This is really what I bought 2 x 2GB Pine64+ boards for :
https://github.com/apritzel/pine64
https://github.com/umiddelb/z2d/tree/master/pine64
I've decided that NOTHING provided by anyone at Pine is going to be of any use.  So gonna build my own use above guides.
I might put the Pine touchpanel on my BananaPI (unfortunately it doesn't have a touch interface connector on the board), shame because what I was hoping was to have a dedicated 64 bit ARM / RISC docker machine, and one that I could run Debian and some X server with touch-panel that I could easily switch to Console only mode...
Not having Bluetooth is a really PITA - but I'll live with that DISFUNCTIONAL aspect of the Pine "stock" WiFi/BT module - and wire in USB keyb/mouse combo - or just use UART and SSH.
(06-01-2016, 10:34 PM)UnixOutlaw Wrote: This is really what I bought 2 x 2GB Pine64+ boards for :
ubuntu@fjords:~$ uname -a
Linux fjords 3.10.101-1-pine64-longsleep #41 SMP PREEMPT Mon May 16 18:30:38 CEST 2016 aarch64 aarch64 aarch64 GNU/Linux
ubuntu@fjords:~$ file $(which docker)
/usr/bin/docker: ELF 64-bit LSB executable, ARM aarch64, version 1 (SYSV), dynamically linked, interpreter /lib/ld-linux-aarch64.so.1, for GNU/Linux 3.7.0, BuildID[sha1]=e8d64ae4829daa6a56d26d620ca80d7e6867be7a, not stripped
ubuntu@fjords:~$ docker version
Client:
Version:      1.10.3
API version:  1.22
Go version:   go1.6.1
Git commit:   20f81dd
Built:        Wed, 20 Apr 2016 14:19:16 -0700
OS/Arch:      linux/arm64
Server:
Version:      1.10.3
API version:  1.22
Go version:   go1.6.1
Git commit:   20f81dd
ubuntu@fjords:~$ lsb_release -a
No LSB modules are available.
Distributor ID:    Ubuntu
Description:    Ubuntu 16.04 LTS
Release:    16.04
Codename:    xenial
care to explain how you installed docker ?
apt update
apt install docker.io
It's not the freshest version, but there seem to be build issues with 1.11.2 right now and it's not old enough that it causes problems.
OK. thank you Smile
  Pine64 will be supported by HypriotOS (a Debian Jessie based OS for running Docker) Quintus23M 9 16,919 02-03-2017, 05:50 AM
Last Post: pfeerick
Big Grin Docker image based on gentoo crossdev arm64 and distcc uulaoba 0 2,985 11-19-2016, 09:34 AM
Last Post: uulaoba
  Docker build UnixOutlaw 0 1,678 06-02-2016, 07:33 AM
Last Post: UnixOutlaw
  Minimal 64bit ARM RootFS for Debian and Ubuntu umiddelb 46 64,858 03-06-2016, 10:28 AM
Last Post: umiddelb
