Rock64 enable 1-wire to read DS18B20 or Dallas temperature sensor
How is the 1-wire bus enabled on a Rock64 ver 2 with Armbian 20.08.17 Bionic? I have enabled the w1-gpio through armbian-config. The /sys/bus/w1/devices/ folder is empty after sudo modprobe w1-gpio and sudo modprobe w1-therm.
Below is what is in the armbianEnv.txt file in the /boot directory.
verbosity=1
bootlogo=false
overlay_prefix=rockchip
rootdev=UUID=cbeeff94-c38d-4a79-b10a-3854a2470be4
rootfstype=ext4
usbstoragequirks=0x2537:0x1066:u,0x2537:0x1068:u
overlays=i2c7 spi-spidev w1-gpio
In the /boot/dtb/rockchip/overlay/ directory there is a file rockchip-w1-gpio.dtbo.
I have connected the VCC pin of the DS18B20 to 3v3 physical pin 1, ground of the DS18B20 to physical pin 9, data of the DS18B20 to physical 7.
The DS18B20 address and w1_bus_master1 do not appear in the /sys/bus/w1/devices/ folder.
What more is required to see the DS18B20 and take readings?
I have already connected an 18x2 LCD to i2c and am writing information to the LCD using python.
Thank you for the help.
Perry
@Perry did you managed to get it working ?
(02-09-2021, 02:43 PM){-DesT-} Wrote: @Perry did you managed to get it working ?
Good morning. I did not get this working.
Thank you
Perry
  Rock64 v2.0 u-boot SPI issues ju0n 0 238 07-05-2026, 11:02 AM
Last Post: ju0n
  Rock64 No Audio @ Debian 12 dmitrymyadzelets 2 5,592 04-08-2024, 06:47 AM
Last Post: dmitrymyadzelets
  OpenWRT on the Rock64 CanadianBacon 14 26,669 04-03-2024, 08:48 AM
Last Post: helpmerock
  Rock64 bricked shawwwn 7 15,792 03-17-2024, 12:22 PM
  Rock64 won't boot luminosity7 10 17,429 03-16-2024, 08:33 AM
  Rock64 doesn't boot dstallmo 1 4,367 03-16-2024, 08:29 AM
  How well does Rock64 deal with HDR and Atmos on Kodi? drvlikhell 3 9,209 04-29-2023, 04:24 AM
Last Post: newestssd
  Rock64 board not working, no HDMI no Ethernet. EDited 3 10,316 01-17-2023, 02:31 PM
Last Post: Flagtrax
  ROCK64 v3 can it boot from USB? Tsagualsa 4 9,562 11-29-2022, 11:31 AM
Last Post: Macgyver
  rock64 v3 spiflash Macgyver 0 4,545 11-28-2022, 02:18 PM
Last Post: Macgyver
