OS Installation
Now I'm definitely sure the issue doesn't lie on the OS. I booted Ubuntu from my USB drive and flashed the PureOS image using BalenaEtcher but the phone booted the postmarketOS beta yet again. Ah!!!
Did you ever get this to work? I use etcher if I am flashing the SD card from Windows but if I am flashing from Linux I use the 'Disks' app.
1. Unmount all partitions of the SD card. (I usually end up deleting all partitions and reformatting the whole card but that is how I roll.)
2. Extract .img.xz to just .img file (Unlike Etcher which uses the zipped file)
2. Select SD card in 'Disks' app.
3. Select Options icon in the top right (I guess that is what you call the three bar icon) and choose "Restore Disk Image"
4. Select the unzipped .img file, select restore, restore, then enter your user password.
(10-31-2020, 12:27 AM)discogribbs Wrote:
Quote:Did you ever get this to work?
Not yet. Thankfully some kind people over at the official Pine64 subreddit are currently helping me. Apparently the issue is rooted in the flashing process itself.
Quote:but if I am flashing from Linux I use the 'Disks' app.
Oh, maybe that'll help.
Quote:1. Unmount all partitions of the SD card. (I usually end up deleting all partitions and reformatting the whole card but that is how I roll.)
Thank you. I'll follow these instructions and report back.
(10-31-2020, 12:27 AM)discogribbs Wrote: 1. Unmount all partitions of the SD card. (I usually end up deleting all partitions and reformatting the whole card but that is how I roll.)
Well... it failed. I completed the above steps using an openSUSE .raw.xz file but I don't think that affected the outcome. From what one person told me yesterday, the issue lies either in the flashing or the micro SD card reader.
I finally was able to install another OS to my phone after flashing JumpDrive to the micro SD card using the PinePhone. Now that I think about it, the problem probably arose from the fact that I was using UMS Enabler on an Android phone so Windows and Ubuntu could detect the micro SD card.
