Hardware Security Switch for Speakers and Gyro
I feel like this should be added to the design if the focus is on privacy and security. From my understanding, speakers can be turned into microphones through software and so can the gyroscope (to a MUCH lesser extent). I only found out about this stuff recently, but I think research was done on this back in 2014, if I recall correctly.
References? They'd be useful in assessing how much of a risk this really is. Also we don't have a hardware switch for the microphone yet, so an attacker could just use that directly.
I suspect there are some specific hardware requirements to use a speaker as a microphone, so you'd need to check whether it's an actual risk in this case.
Accels have been used as a side channel for touchscreen inference, so using gyros and magnetometers as a side channel is plausible:
https://www.researchgate.net/publication...martphones
Although if it's probably hard to turn speakers into microphones, one can leak data using speakers as they are: https://github.com/romanz/amodem/.
Very interesting. HOwever, it is really a threat? I have no idea of this, and I just searched. All I found it needs physical manipulation.
  Microphone on Hardware Model 1.2 is Unusably Noisy In Some Circomstances ASmartSuitedSimpleton 4 3,926 03-23-2024, 10:55 AM
Last Post: Ferriah
Question bluetooth speakers and pinephone pro Supervisor 2 1,262 01-30-2023, 09:21 AM
Last Post: Supervisor
  Is the hardware still being developed and refined? orbital 10 5,017 09-01-2022, 08:05 PM
Last Post: orbital
  How to check hardware revision? jojuma 1 1,595 07-16-2022, 12:28 AM
Last Post: bokomaru
  Modem Hardware bad? Not ready for 5g?? linux76 8 4,721 05-31-2022, 06:41 PM
Last Post: SwordfishII
  Any experiences with hardware mod to improve eMMC speeds? kqlnut 9 5,973 04-19-2022, 02:36 PM
Last Post: kk22
  Hardware switch for mic is not working properly submariner 10 7,679 01-25-2022, 07:01 AM
Last Post: wibble
  Case hardware request/idea HobanWashburn 5 4,510 09-15-2021, 04:02 AM
  PinePhone Hardware Critique KABA 2 2,905 08-13-2021, 06:47 PM
  LED hardware/schematic bug immibis 1 2,032 08-06-2021, 10:44 PM
