mhwd-kernel: command not found
I am trying install virtual box https://wiki.manjaro.org/index.php/Virtu...on_Manjaro
The first line says to check the kernel type but entering the above command throws an error. How can I debug this?
It's a  new in Fall 2020 PBP with the default manjaro but I don't know how to check the exact specs yet Sad
uname -a
And, it won't work, all examples are arch=x86_64, none with simple name "virtualbox"
IOW, not for ARM64, aarch64
And I would also bet that if you altered the arch line, the compile would "error out"
but don't let me discourage you, give it a try
--edit-- mhwd-kernel is almost certainly a x86 command
  Manjaro pinebookpro images with kernel 5.7.19 rfm83 11 13,304 01-22-2023, 10:05 PM
Last Post: rfm83
  Broken usb-c to hdmi with kernel 5.18+ rfm83 6 7,993 01-22-2023, 09:55 PM
Last Post: rfm83
  minimal kernel .config? alchemist 5 10,367 08-15-2022, 06:28 PM
Last Post: svmhdvn
  Kernel panics on Youtube solostian 1 3,693 12-26-2021, 11:45 AM
Last Post: sirspate
  Screen refresh delay with kernel errors shawnanastasio 31 60,162 04-27-2021, 02:57 AM
Last Post: james64
  I/O errors from SD card slot? (Manjaro, kernel 5.7) zackw 5 13,911 10-28-2020, 01:16 AM
Last Post: 25519
  apt-get command not found motezart 11 19,389 09-25-2020, 11:45 AM
Last Post: Paulie420
  Boot custom kernel on PineBook Pro lowenware 7 14,402 07-06-2020, 03:31 PM
Last Post: lowenware
  Changed the bootsplash image - Kernel messages still showing Twix166 7 13,595 01-16-2020, 05:51 PM
Last Post: Arwen
  Debian: How to get kernel header files crusty 2 6,599 01-08-2020, 02:22 PM
Last Post: muma
