Mobian for x86_64
Hi.
I would like to ask if it is possible to have x86_64 builds of Mobian.
I have a gpd win 2 with a 6inch touch screen and would be nice to have phosh on it, there is also multiple x86_64 tablets out there that will benefit from it too.
Regards!
(10-13-2020, 03:22 AM)paju1986 Wrote: I would like to ask if it is possible to have x86_64 builds of Mobian.
Technically, it's already possible yes, as long as you build the image yourself: get the debos recipes and build using "./build.sh -t amd64"
On the GPD, as it's more or less a standard PC with well-supported hardware (from what I know), I'd rather suggest you install Debian (testing) on it, and then enable Mobian repos using "extrepo enable mobian" (you'll have to apt install extrepo first, of course). Then, package mobian-phosh should bring in everything you need to run phosh on your device Smile
  Mobian MMS/SMS text problem bcnaz 16 38,606 06-23-2026, 06:53 AM
Last Post: mehdy
  Mobian image for the PinePhone Korfou 2 1,642 04-27-2026, 09:57 AM
Last Post: Korfou
  bookworm vs trixie discussion for mobian in pinephone regular. zetabeta 80 67,012 12-24-2025, 12:11 AM
  cryptocurrency on mobian/pinephone biketool 33 72,618 10-08-2025, 06:21 AM
  XLibre for Mobian Hiraghm 0 3,310 06-29-2025, 12:38 PM
Last Post: Hiraghm
  Axolotl on PinePhone / Mobian arno_nuehm 223 341,676 06-25-2025, 01:19 PM
Last Post: anonymous
  VoIP account on mobian dialer j_s 0 2,986 06-15-2025, 04:19 PM
Last Post: j_s
  Mobian Pinephone Notification LED biketool 2 4,110 06-07-2025, 03:19 PM
  Vivaldi Web browser nearly native for Mobian biketool 3 4,846 05-06-2025, 02:19 AM
  mobian calamares fail merom 2 4,565 04-29-2025, 02:10 PM
Last Post: mdk
