wine-stable
Does anyone have any success installing wine-stable on manjaro pinebook?
I tried with activation AUR and running it with pacmac without success. after a while it hangs up in the checking/cloning.
thanks,
Paul
Err, if you click in pacmac, it will show build files
arch=(x86_64)
Even if you stuffed arm64 into that string, still would not work, sorry
And if you meant windows arm, I don't think wine can do that
anyway, a miniscule market
(10-11-2020, 07:40 PM)wdt Wrote: Err, if you click in pacmac, it will show build files
arch=(x86_64)
Thank you wdt.
i want to run a Windows program on my Pinebook pro. Is there another way?
I saw a youtube video, someone used qemu to install a winpe (windows pre-install environment)
It took quite a while, ??,,, 2 minutes?? for desktop to show
So, find something else that does same thing?? or "eats" same data files?
(that is an arm native)
Now if it a dos program, box86 is progressing quite well, when "done" it will be exceptional
Sebastion has been working on it for a few years now, maybe 90-95% "done"
since the goal is game play, video drivers are a BIG factor
Hangover (Wine for Arm64 and Power) got a new Alpha release: https://www.phoronix.com/scan.php?page=n...er-Alpha-2
Bug [Fixed] Issue with mesa-git (Manjaro ARM Stable Update 2020-09-22)) JasonG-FR 20 36,398 12-12-2020, 05:09 AM
Last Post: mogwai
  Hangover (wine) on the Pinebook Pro PakoSt 5 9,011 01-16-2020, 09:14 AM
Last Post: PakoSt
Lightbulb Wine on Pinebook Pro colemancda 6 11,309 11-27-2019, 09:30 AM
Last Post: Idaho
