Pinephone Community Edition doesn't boot from SD-Card Only Red LED
(09-08-2020, 09:52 AM)robthebold Wrote: September 6 build (#78) boots on 3GB phones
No need to mess around with the nightly/test builds unless you want to. The latest stable release from Sep 5 works on 3GB phones. I'm currently running the F2FS build from eMMC.
Aren't they one and the same in this case, or am I looking in the wrong place? (https://ci.ubports.com/job/rootfs/job/ro...stemimage/)
Are you referring to Mobian "from Sep 5" works ?
On Mobian the Sep 5 release is considered  "stable"  while the "nightly's" are considered cutting edge or testing.
They are listed in the same list on the download page,  but certain ones are considered "stable"
I do not know if ubports has some that are considered as "stable", they may have some also..?
ubports does also do nightly builds like Mobian.
Yes. I'm taking the stable terminology from Mobian and trying to make clear that you don't need a nightly build to boot on a 3GB phone. AFAIK the ability to boot on 3GB phones is what makes the Sep 5 build the latest stable one. That being said, we need people to use the nightly builds. Thanks for your efforts.
To your other point, stable/test builds in UBports are controlled with the options found at System Settings > Updates > Update Settings. I enabled "Release Candidate" to update to OTA-13. At some point, OTA-13 will be promoted to "stable" and be used for the nightly builds. I guess this means that the nightly UBports builds are stable builds, too.
  PinePhone - boot from microSD laserpyramid 7 639 04-25-2024, 05:56 AM
Last Post: aular
  pinephone virtual keyboard aular 4 369 04-10-2024, 03:45 PM
Last Post: aular
  PinePhone Doesn't Boot LED Doesn't Show Any Signs When Charging dorkydev 1 249 04-02-2024, 11:50 AM
  install iso from sd card to emmc aular 2 350 03-11-2024, 10:24 PM
  Are you using the Pinephone as your daily driver? jro 157 109,752 02-18-2024, 11:33 PM
Last Post: aular
  2020 PinePhone Manjaro CE EU for sale, name your price astrojuanlu 7 1,858 02-14-2024, 04:51 PM
Last Post: astrojuanlu
  pinephone is not bootble for the box. ijij 1 626 01-19-2024, 01:29 PM
Last Post: fxc
  How To Access the Pine Phone Auxillary microSD Without Removing Card pinephoneuser22 2 971 01-09-2024, 07:02 PM
Last Post: britelite
  Multiple issues with the Pinephone MTXP 12 2,412 12-28-2023, 07:55 AM
Last Post: MTXP
  pinephone repair shop shengchieh 0 512 12-26-2023, 02:42 PM
Last Post: shengchieh
